Another Windshield Thread
Old May 20, 2010 | 05:55 PM
SBRob's Avatar
SBRob
Good luck with the windvest...I have the HD QD low profile shield and had it adjusted just about right to minimize the buffetting with the stock bars...BUT, when I changed out the bars it changed my ridiing position which added more buffetting.
The shield now spends about 95% of the time in my "parts room" instead of on the bike.
Old May 21, 2010 | 04:33 PM
Dale_K's Avatar
Dale_K
Please post up something if you get a solution. I tried the QD compact and the QD "barn door" on my 2010 FXD and they both buffeted my head so much I could hardly see. Surprising because my old FLHS had a police type windshield and it didn't buffet.
Old May 22, 2010 | 06:00 PM
army_eod's Avatar
army_eod
Hey..I fixed the windshield buffet...took it off. I like it now. If the new WindVest does not do the job, I guess I will be shieldless...LOL
HD QD is on eBay now...
Old May 22, 2010 | 07:28 PM
mp's Avatar
mp
The problem I see with most windshields is they are too upright. That's guaranteed to cause buffeting. Bikes with instruments on the handlebars are guaranteed to have upright windshields. The solution is to relocate the speedo and get a windshield that can be raked.
Old May 22, 2010 | 07:37 PM
OldMike's Avatar
OldMike
With the Windvest windshield I just mounted I'm able to adjust the rake and also it can be raised or lowered two inches. I probably don't have it dialed in completely but mine is raked slightly more than the natural rake of the forks, meaning the top is tilted back. It is a day and night difference from the Harley shield. I'm 5'10" and the 16" model seems to be the perfect fit, I look right over the top of it.
Mike
Old May 24, 2010 | 05:30 AM
army_eod's Avatar
army_eod
Mike
My FXD has the speedo on the handlebars. I hope that is not a problem for mounting. When I spoke to the guy at the WindVest factory, he acknowledged the model of bike and that the speedo is on the bars, so I am hoping it works...or they will make it right, they said. The key for me is NO buffeting allowed on the head. That is why I removed the stock shield. I can see clearly now.
Old May 24, 2010 | 08:24 AM
jcopel's Avatar
jcopel
Originally Posted by army_eod
I really think the wind is buffeting the side of the helmet...not the top, but I don't know.
I'm getting the same thing with a new Memphis Shades Del Rio I purchased in January. Most of my turbulence seemed to be coming around the sides also. Mine hangs in the garage now, and that's the best place for it.
I just wanted to ask you how tight is your helmet. I wear a 3/4 with shield and mine's a little loose now. When I wear a beanie cap or do-rag under my helmet, the buffetting was not near as bad. It really made a big improvement. Something you may want to consider.
Old May 24, 2010 | 01:01 PM
Romark's Avatar
Romark
I had the same issues with the HD quick detach on my '07 Wide Glide. Just left it off the bike. Bought a Windvest and will never take it off. I haven't even tried to fine tune it. It's that good. I'm 5' 10""
Old May 24, 2010 | 02:22 PM
jaxdwg's Avatar
jaxdwg
What you need to do is go for a ride at 60mph and put your left arm across your chest, like a salute, so you can determine where the buffeting is coming from. What happens in most cases is that the shield turns the air hitting it upward and over your head, but, that process has now created a low pressure area behind the shield. the air traveling under the shield is now drawn up into that low pressure area in an attempt to equalize the pressure. That is the air that comes up the front of your body and is trying to blend with the air going over the top. think about the water in a river going around a big rock, one side seems to go smoothly around the rock and the other is drawn in and swirls before it rejoins the flow on the other side. The problem is that your head is the point where the two wind currents rejoin, thus the buffeting. You have 4 remedies to the problem, 1 take off the shield and eat all the wind,2 you can put a full faring on your bike, 3 you can put lowers on the forks which works but the deflected air at that level also deflects the air that flows by your legs and butt and lets the engine heat rise to make your legs and butt much warmer on a hot day, although it can be nice in the winter time. and 4 you can wait to deflect that updraft until it is at chest level then re-direct it outward from the centerline of your chest and send 1/2 of that updraft over each shoulder which eliminates the combining of the 2 currents at your head. You will have all the wind you ever had except from your chest up, which is where you don't want the wind anyway, correct? google jack's flaps and watch the video, then make up you own mind as to what you should do for the buffeting problem. Sorry for the long-windedness but it was the only way I know to articulate the aerodynamics occuring with the windshield
Old May 24, 2010 | 04:01 PM
army_eod's Avatar
army_eod
This is good news...I am also 5' 10. The WindVest is due in Thursday. I get new bars mounted tomorrow.
