Avon front tire
I have an 01 FXDX which takes a 150X80X16-inch tire. They make them all day every day. I see you have an 07 and they probably switched sizes huh? I hope they make that size cause I really do like these tires.
BTW thanks for the feedback on the Night Dragons. I think I may try them!
DaFish
DaFish
DaFish
DaFish
CB
Yes, I want to take advantage of the rebate because I am short on funds and that is why I wanted to get more feed back on the tire because I also want a great handling tire and do not like to change what works for an unknown when I have limited funds, but would not mind saving a few bucks on a safe good handling tire.
I also said I did not want to make this about mixing so lets not be pissy about my personal preference.
I went ahead and sent Avon a message and I'll bet you that they say to refer to the motorcycle manufacturers recommendations, just like Dunlop, Metzeler and Pirelli have, so that leaves me where?
I do appreciate your input.
CB
CB
I have been riding for decades and covered almost half a million miles on bikes and have never used the recommended tyres as replacements for the many brands of bikes I have owned, because they are seldom very good. My first new Harley had Goodyears and I wouldn't wish them on anyone!
As for new tyres for your bike, you can obviously get a rebate for a Venom front, but unfortunately you can't for a replacement rear. I personally never mix brands. You have to decide to get the recommended Avon rear, at whatever they cost, or buy a different brand if you can get a pair for less.
As for Avons, the reason I prefer them is because they have excellent grip in all weathers, handle extremely well when riding quickly, are comfortable because they use clever designs to give a good quality ride, and give decent tyre life. If you do buy Avons, check their website, because they often recommend slightly higher pressures (see my earlier post for them), which may be different from your owners handbook.
And best of luck! If you chose Avons I expect you will be very pleased with them. I have been using them for almost 40 years! I am just sorry you can't get a rebate on them both!
There are three sizes suitable for us Harley riders. Avon makes a stock size 130/90 equivilent to an MT, a 140/90 which is similar to a MU, as well as a 150/80 which is also rated MU. All will fit a 3" stock rim.
Having previously mentioned writing to Avon with any queries, they actually recommended I use their 140/90 on my old Glide in preference to their 130/90, because they reckon when 2-up and fully loaded the MT is close to its limit on loading. It was a small leap of logic to use their 150/80 instead, which with various mods just squeaks into my 1990 FLHS!
That's the tire I put on the front. I can't believe how much of a difference it made over the stock Dunlop. The front end is way more stable. Went with the stock size Storm on the back and love the results. I don't know if there is more lean angle, but I feel more confident carving corners.
I like my Night Dragons, but I was thinking of getting a Venom 110/90-19 which the Night Dragon does not come in, plus Avon has a $25 rebate per tire until the 31st, too bad they don't make a 17" to fit our stock rear wheel because I would like to match.
To those who have the the Avon Venom front tire how is it working out? Does it really stick good in the corner and what are you mixing with it on the rear? I don't really need a front tire right now, but I figured I would buy the front, then use the $25 gift card to help pay for a New rear Night Dragon that I am going to need sooner than later and I then have a front tire when the time comes.
CB
http://www.motorcycle-superstore.com...bra-Tires.aspx
CB
I put Venoms front and rear on my 98 fxd last week. I've got about 300 miles on them now and no issues. I like them so far. I haven't done any peg scraping yet, but they do seem to dig into the corners pretty damn good when I hit the on and off ramps a little hot.
++++1 Jack
Hi CB, you can mix radial and bias tires but the radial has to be used on the rear. This combination is recommended for your bike and will not be a problem.
Kevin Corbett
Mickey Thompson/Dick Cepek/Avon Motorcycle
Technical Service Representative
1-800-222-9092
Ext.3169
Submitted values are:
Contact country: USA
Your name: CB
Your subject: Mixing Radial and Bias ply
Your message:
Do you recommend these tire for a 2007 Harley Davidson Street Bob with wire
spoked wheels.
Front tyre
Venom
Pressure front:
2.5 bar (36psi)
Front size:
100/90-19 57H
Rear tyre
Storm 2 Ultra
Pressure rear:
2.8 bar (40psi)
Rear size:
160/70R17 79V
Thank you
Date: Friday, 28 May, 2010 - 15:11
Kevin Corbett
1-800-222-9092
Ext.3169
Your name: CB
Your message:
spoked wheels.
Front tyre
Venom
Pressure front:
2.5 bar (36psi)
Front size:
100/90-19 57H
Rear tyre
Storm 2 Ultra
Pressure rear:
2.8 bar (40psi)
Rear size:
160/70R17 79V
Thank you
Sticky4
May 9, 2012 07:00 PM
