remove tail light and bracket
Old 06-05-2010, 11:37 AM
bbqbrisket's Avatar
bbqbrisket
bbqbrisket is offline
Default remove tail light and bracket
I need a little help on understanding how to remove the tail light assembly and bracket from my 05 wide glide.
I am replacing it with a custom style one.
I have the shop manual and parts and all I can see is the 2 obvious screws that hold the lens cover. It's not to clear to me right now. Maybe once I take it apart it will become obvious.
However, appreciate any help before I start removing screws.
thanks
Old 06-05-2010, 12:47 PM
dmftoy1's Avatar
dmftoy1
dmftoy1 is offline
I don't know how different a WG might be from my low-rider, but on my low rider you remove the two lens screws and take the lens off and then there's a BIG phillips screw that you take ou in the center . .it then has tabs that are hooked into the fender and slides (slightly) down/out.
Hopefully that makes sense.
Have a good one,
Dave
Old 06-05-2010, 12:57 PM
bbqbrisket's Avatar
bbqbrisket
I think it makes sense.
Low rider is probably the same
thanks
Old 06-05-2010, 01:00 PM
maduxfn31's Avatar
maduxfn31
maduxfn31 is offline
Thats the same way the light on my 2000 wide glide is also
Old 06-05-2010, 02:55 PM
bbqbrisket's Avatar
bbqbrisket
I just read in the 05 dyna service manual that the circuit board is not held in place with a screw.
Not sure what that means.
bbqbrisket
07-01-2023 03:51 PM
toku58
07-21-2013 12:57 AM
IceMan1
General Topics/Tech Tips
09-12-2011 10:56 AM
chevypilot
01-28-2011 06:17 AM
bobx67
11-24-2008 06:37 PM
Quick Reply: remove tail light and bracket
