Intake Install guide...
Old Jul 9, 2010 | 04:10 AM
Krazy8s's Avatar
Krazy8s
Smile Intake Install guide...
A friend has given me a Wimmer style 90 degree intake with top breathers to try out on my bike. he bought it and never used it!
No idea what brand the intake is or where it comes from, but it looks good, nicely made & good finish, and if it works better than the stock AC then nothing lost I guess.
Only issue is that it doesnt come with any instructions. Not that it is a difficult thing to put on, but it would be nice to know (or at least have a vague idea of) what order various washers, spacers and breathers go on just to save time messing about.
Does anyone have the wimmer install destructions for the 90 degree basic intake that they could scan and post here so that I can use it as guide please. The schematic link on the wimmer site is broken so I cant download it from there...
Once i get the intake on i will post pics.
Many thanks in advance!
Old Jul 9, 2010 | 08:28 AM
08fxdf43202's Avatar
08fxdf43202
Here's how I did my K&N intake I picked up for $20.
It came with one of these type brackets... ... for a Sportster.
I cut the 'wings' off to use just the round part that bolts to the throttle body. I welded it to this black bracket which I made for a previous AC I had.
The crankcase breather tubes are automotive windshield washer tubing joined with a 'T' fitting & routed into the AC through a tight fitting hole drilled into the top of the elbow. I cut down the length of the stock breather bolts & used brass washers between the cylinder head & black bracket.
I know this may not answer your inquiry, but it might inspire your imagination for a creative solution.
This 90* intake has given me a noticable gain in preformance over the 'open' round Screaming Eagle type AC I had.
Old Jul 9, 2010 | 08:38 AM
Krazy8s's Avatar
Krazy8s
that's a sweet bit of work, and mission accomplished, I am inspired!
Old Jul 9, 2010 | 08:51 AM
Krazy8s's Avatar
Krazy8s
Guy that gave me the kit found the site he bought it from.
Here is a pic of the kit for anyone interested:
Old Jul 9, 2010 | 08:59 AM
SC-Longhair's Avatar
SC-Longhair
Krazy...I have the same one except mine isn't pointed. It's flat.
I don't like it. Lots of blow-by with those breathers. Read: you will have a mess of oil on the right side of your bike after a long ride.
I went back to my SE stage 1 round cleaner.
Oh, and it's a puzzle. Just put it together. Mine came with no install sheet either. I emailed Wimmer because the a/c are practically the same. From their diagram, I was able to get it on. If I can find the email I'll send it to you.
Old Jul 9, 2010 | 09:10 AM
Krazy8s's Avatar
Krazy8s
Diagram would be Brilliant!
Was a bit concerned about the oil thing myself as I have read other posts that mention it.
Having been inspired by 08fxdf43202's build i might look at seeing if I can fabricate breather pipes instead. He's got a neat solution there.
At the moment I have only the stock filter, so for a cost of almost nuthin' I should get some improvement over the stock.
If not then I have had some fun, got my hands dirty, and learnt something along the way
Thanx for the advice!
Old Jul 9, 2010 | 09:27 AM
SC-Longhair
I found the email. If you want the fullsize pdf, PM me your private email. Be happy to forward it. That's too small..... gimme a minute.
EDIT:
http://i64.photobucket.com/albums/h1...at102613AM.png
bigger.
Old Jul 9, 2010 | 10:02 AM
Krazy8s's Avatar
Krazy8s
PM sent.
Many, many thanks!!
Old Jul 9, 2010 | 11:56 AM
08fxdf43202
For 0 dollars... I'd cut the filter heads off their stems, rotate em straight up & rout rubber tubing through a hole in the top of the elbow.
Or, for $42.99... you could go with one of these kits: http://www.jpcycles.com/product/4000...000283&Ntk=All
... so you wouldn't have to mess up those nice lookin' filters
Old Jul 9, 2010 | 12:23 PM
Krazy8s's Avatar
Krazy8s
Many thanks to 08fxdf43202 for inspiration on the Breathers and SC-Longhair for the wimmer schematic.
Mucho Kudos to both!!
tjcaron
Audio Systems
May 28, 2019 03:25 PM
Ndoggct
Apr 29, 2013 06:50 PM
Cruiseman
Harley Davidson Videos
Mar 8, 2013 07:17 AM
WhiteSS
May 15, 2008 09:26 AM
