Engine start/running problems
Old Jul 23, 2010 | 12:50 PM
mac8985's Avatar
mac8985
Default Engine start/running problems
Hi
I have a 01 Dyna with carburetor.
When I turn the ignition switch to start the engine sometimes the ignition lights come on and sometimes they don't.
If the ignition lights do come on when I try to start the engine sometimes its starts and sometimes it just makes a clicking sound.
If I do manage to get the engine running, when on the bike it seems as though it's 'missing', the speedo gauage shoots up and down to the speed I'm doing and the digital mileometer flashes on and off. Other times and can run ok.
I've put a new Odessey battery on and checked all the obvious stuff like leads/connections etc. Any advice would be greatly apreciated because I'm at a dead end!
Thanks
Old Jul 23, 2010 | 11:39 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You've got either a pinched wire or a burnt wire making contact with the frame somewhere. Or,,,,,
Voltage regulator could be tossing it's cookies.
Old Jul 24, 2010 | 02:47 AM
clicker01's Avatar
clicker01
Have you tried checking for codes?
Old Jul 24, 2010 | 05:14 AM
mac8985's Avatar
mac8985
Thanks for the replies, not sure what you mean by codes?
Old Jul 24, 2010 | 11:12 AM
Derv's Avatar
Derv
It's an 01 carbed bike!!
Derv
Old Jul 24, 2010 | 11:29 AM
Grendel4's Avatar
Grendel4
Derv
I think some of the carbed models have a 'computer' that advances and retards timing.
Old Jul 24, 2010 | 03:05 PM
clicker01's Avatar
clicker01
Derv
My bad!! As that being the case, it should be relatively easy to correct. Does the op have a service manual on the bike? Fuel + fire + air = a running engine. It sounds like multiple issues, one being the start circuit and two being either the fuel or ignition systems, or both. Is the gas fresh? what do the spark plugs look like? Coil, plugs, plug wires? Carb clean, fuel filter, lines? The list goes on. First, get the start circuit working consistently, then you can start finding the run problems. You really should have the service manual and run through the flow charts. Or, you could just find a good indy shop and be done with it...
Old Jul 24, 2010 | 05:04 PM
dyna rider's Avatar
dyna rider
Default Starting and Running
Have you done a handlebar mod or switch lately or is the rear end lowered ? Have you checked the battery terminals at both ends ?
Old Jul 24, 2010 | 08:58 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Was the bike having these problems before you changed the battery?
Old Jul 26, 2010 | 03:08 PM
mac8985's Avatar
mac8985
Apes wre put on the year before last with no problems, terminal leads are all good.
