S&S easy start 583 cam??
Old Oct 24, 2017 | 10:45 PM
  #51
sharkey's Avatar
sharkey
My bike has 583 NOT 585 cams...no edit icon on original post...sorry
Old Sep 10, 2018 | 12:20 PM
  #52
Yann Ftn's Avatar
Yann Ftn
Stage I
Originally Posted by SURFOR Chop
Had not thought of the higher lift cams causing additional load on the starter ... makes sense ... the additional force of overcoming the valve springs at the marginal spring rate beyond stock .473/.474 ... (does not seem like it would be that much) ....
However, I do not see why cams alone would increase the "static compression ratio" ... the def is the combustion chamber volume divided by the swept volume of the cylinders plus the combustion chamber volume ... nothing in that equation is changed by higher lift cams ...
If anything, my understanding is that the dynamic compression ratio could be decreased a little due to increase in overlap of Int/Exh of the replacement cams ....
What am I missing ...?
I there,
I am looking at putting the 583 sns am into my bike Is there any problème with the original valve spring? Does it need to be replaced or original part are OK?
Tx for the response
Old Sep 10, 2018 | 04:30 PM
  #53
Durham man's Avatar
Durham man
Originally Posted by Yann Ftn
I there,
Tx for the response
Old Sep 11, 2018 | 07:47 AM
  #54
slippin_jimmy's Avatar
slippin_jimmy
Originally Posted by ELECTRICMONKEY
Anyone with the 583 EZ cams still happy? and how many miles have you had them?
I just ordered some and installing tommorow.
+1 on the 583's. Great all around cam. I did the quickee pushrods and new lifters from S&S. I've been running it all summer. The bike should run like this from the factory. I also did the powervision which helped dial the bike in further. I had a fuelpak at first and I spots in the throttle where the bike fell flat. Good luck and check runout at crank pinion shaft. Should be below .030 or stick with chain drive.
Old Sep 11, 2018 | 07:59 AM
  #55
Durham man's Avatar
Durham man
S&s hp 103 cams, S&s premium lifters, head work , compression set at 10.2., 30 tooth power pulley. 100 - 100 club. Good to go.
Old Sep 11, 2018 | 08:01 AM
  #56
Durham man's Avatar
Durham man
I went power camander & dyno tune. Very happy with my set up!
Old Sep 16, 2018 | 01:36 AM
  #57
Krazy8s's Avatar
Krazy8s
I installed 583 ezy starts on my 103 build, love them.
Something Dynojet and V&H DONT tell you.... Auto tune isn't an option on modded cams using just the standard tuner alone, you need the wide band add ons to Autotune Cams.
My only regret is using an FP3 instead of the PowerVision and a dyno tune, or forsake the dyno tune and get the Target tune option to be able to Auto tune with the modded cams.
Just to clarify, nothing wrong with the FP3, it just turns out that finding a Dyno shop on this side of the Pond that can/will tune with an FP3 is akin to finding Rocking Horse poop...
Old Sep 16, 2018 | 03:06 AM
  #58
66cruiser's Avatar
66cruiser
I wanted more passing power on 2 lane roads and got it with the 583G cams. also added the S&S 97/106 kit and pv1. very happy with the results, never any problem starting but I keep a battery tender on whenever I'm not riding.
Old Nov 4, 2021 | 05:30 AM
  #59
Damien 604 - 05fxdc's Avatar
Damien 604 - 05fxdc
2nd Gear
Originally Posted by dyna rider
I have S&S 585's and they are an upper RPM cam. Comes on about 4000 and climbs like crazy to 6500. It's got pretty good grunt (torque) but it is higher up in the RPM range. I know H-D 211's have good low end torque and lots of guys on here love the Woods cams. I'm sure they will speak up about YOUR decision.
What bike? Stats?
Old Nov 4, 2021 | 05:42 AM
  #60
Damien 604 - 05fxdc
2nd Gear
Originally Posted by sharkey
2008 FXDF with HD 103 kit (10:1 cast pistons), RB 2-1 Black Hole pipe (for quiet), 585 E-Z starts and stock heads. The dyno tells the story; and I wouldn't be without E-Z starts again. Put 551 E-Z's in wife's stock 96; nice upgrade and easier starts when hot
Chart states 583*
Proline1969
Feb 21, 2020 02:43 PM
SuperGlide_805
Dec 21, 2016 02:42 PM
Ryan8585
Apr 23, 2013 12:54 PM
TAC1
Apr 3, 2011 11:18 AM
MCSarge
Exhaust System Topics
Aug 24, 2010 06:26 AM
