Hello, I am in the middle of installing some night train bars on my 2010 Wide Glide. I purchased some 6" risers from J&P. I have them installed and as tight as I can get them and when I turn the handle bars the risers move slightly the direction I am turning. Is this normal?
+1 Try replacing the rubber riser bushings with polyurethane bushings. It will firm up the risers and get rid of the flex problems you are having. You may get a little more vibration in the bars at idle but off idle it will smooth out.
Try a 1/4" shorter Bolt............The risers are not drilled and tapped the same as HD. I think you are bottoming out the bolt before you get the risers properly tightened.
Damn, didn't you read the instructions..............OK, they left that part out.
I hated the sloppy feel of the stock rubber bushings on my bike so when we swapped bars we also put in the poly bushings. Ahhh much better and I notice no extra vibration, just a solid feel.
I'm riding out of town this Sunday, so I am going first thing in the morning to pick up some poly bushings at my local dealer. I hope they have them in stock!!!
Oh just to brag a little, the Night Train bars look sick on my Wide Glide!
