Handlebar clamp screw torque?
Old Oct 18, 2010 | 01:13 PM
66cruiser's Avatar
66cruiser
Default Handlebar clamp screw torque?
Can anyone tell me where in the service manual the torque specs for the handlebars & riser screws are located? I know it must be in there but I can't seem to find it. ('06 Street Bob). Thanks
Old Oct 18, 2010 | 01:25 PM
SC-Longhair's Avatar
SC-Longhair
It's probably covered in the "front end" section of the manual.
Old Oct 18, 2010 | 02:07 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Default torque specs
Couldn't locate the info in my 2003 Dyna Models Service Manual so I checked some Instruction Sheets for risers. Found this info for you:
If using two (small) top clamps:
"Secure handlebars to risers......by tightening the screws until the front and rear gaps between caps and risers are equal. Tighten the screws to 144-180 in-lbs (16-20 Nm)"
"Secure risers from the bottom thru upper fork bracket up into risers. Tighten to 50-60 ft-lbs (68-81 Nm)
From another IS if there's a large riser top clamp (4 hole type):
"...tighten the the front socket head screws to 12-15 ft-lbs (16-20Nm)". There should be no gap at the fron of the risers. Tighten rear socket head screws to 12-15 ft-lbs (16-20Nm)"
Note the difference between ft and in lbs!!
Old Oct 18, 2010 | 02:09 PM
SteveO-ll's Avatar
SteveO-ll
Handle Bars ~ 12-16 ft-lbs (pg 2-72 in my book)
Risers ~ 30-40 ft-lbs
Riser Cover ~ 50-60 in-lbs
Old Oct 18, 2010 | 06:55 PM
66cruiser's Avatar
66cruiser
Thanks guys, got 'er done. Also found the torque specs under "critical fasteners" in section 1 page 48 of the 06 dyna service manual...
Old Oct 19, 2010 | 12:53 AM
FXD2003Rider
Anxious to learn what the Manual reads on the torque specs..
Old Oct 19, 2010 | 09:11 AM
66cruiser's Avatar
66cruiser
'06 dyna service manual:
Riser clamp screws: 12-18 ft-lbs
riser lock nuts: 30-40 ft-lbs
Old Oct 19, 2010 | 09:55 AM
Ratbob's Avatar
Ratbob
Lightbulb
In the '08 book there is a table of torque values in an appendix. Try looking in the back of your manual, might get lucky.
johnpem
Dec 28, 2012 05:47 PM
pheur
May 10, 2012 02:45 PM
meatpunch
Aug 12, 2011 08:22 PM
Taddeoeg
Jan 10, 2010 07:15 AM
saltydawg
May 15, 2009 12:57 PM
