'07 FXDL - Removing stock shift peg
Old Dec 7, 2010 | 04:43 PM
Stevea's Avatar
Stevea
Default '07 FXDL - Removing stock shift peg
I bought a Kuryakyn shift peg cover (#8004) for my Low Rider. I tried using vice grips to unscrew the stock peg. It is on very tight and I did not want to snap the stalk which the peg is screwed into. Is there a way to remove the stock peg easily? Do I need to cut the stock rubber shift peg cover off first?
Old Dec 7, 2010 | 05:07 PM
DYJ's Avatar
DYJ
It's got loctite on it. A lil heat will make easy work of it
Old Dec 7, 2010 | 09:28 PM
Slipstrm's Avatar
Slipstrm
Vise grips on the rubber part and twist it off.
Old Dec 7, 2010 | 11:34 PM
Stickman81's Avatar
Stickman81
I cut back a bit of the rubber on the shift peg to get a better grip with the vise grip pliers.
dsb189
Nov 11, 2009 07:13 PM
Dbl B
Jun 16, 2008 10:55 PM
tom134
Oct 19, 2007 11:30 PM
rvisdew
Dec 19, 2005 06:43 PM
12Stones
14
Mar 11, 2005 06:00 PM
