Shifter Peg Replacement
Old Oct 19, 2007 | 12:47 PM
tom134's Avatar
tom134
Default Shifter Peg Replacement
Anybody know how to remove the shifter peg? Mine is stock and want to replace it. Can I just use a utility knife to cut away the rubber to get to the screw? Thanks in advance.
Old Oct 19, 2007 | 12:56 PM
alphakayak's Avatar
alphakayak
Default RE: Shifter Peg Replacement
Hi,
I replaced mine also. It was tight due to the locktight that had been used. I wrapped a rag around the rubber portion and used vice grips to untighten the shifter peg. Had to use some muscle to get it loose. Using the rag helped prevent from ruinining the rubber on the original peg just in case I wanted to perhaps used it again. Try it, it worked for me.
Kayak
Old Oct 19, 2007 | 01:01 PM
Sammi's Avatar
Sammi
I don't think there is a screw.
The entire peg screws in.
To remove, use vice grips
Old Oct 19, 2007 | 01:08 PM
Finn111's Avatar
Finn111
I tried the Vice Grips first and they just tore the rubber, so I ended up cutting it off with a razor knife, then the Grips worked great.
Old Oct 19, 2007 | 01:31 PM
aviator's Avatar
aviator
my Fatty is held on with an allen head bolt. took all of 5 minutes to change 'em out.
Old Oct 19, 2007 | 01:41 PM
tom134's Avatar
tom134
Thanks for the info guys!
Aviator - is that allen bolt on the outside end of the peg? I'm going to try the vice grips first and then move on to the utility knife.
Old Oct 19, 2007 | 03:01 PM
aviator's Avatar
aviator
yep - right on the outboard side.
Old Oct 19, 2007 | 03:06 PM
user 4636474738's Avatar
user 4636474738
Just use channel lock pliers and it came off with out a lot of force and the rubber still looks fine. Really no reason to cut off the rubber. Counter clockwise to remove.
Good luck..[sm=signs003.gif]
Old Oct 19, 2007 | 11:30 PM
bensonjv's Avatar
bensonjv
You can try some penetrating oil from the inside of the shift lever to get some on the threads. Heat would help reactivate the locktite too.
Like everyone else said, wrap with a rag or something and then use vice grips, robo grip, or other to wrench it off. If it's just too hard for you, destroy it and then take it off. You're putting a new one anyway. Plus, if you need to put a stock one back on they are cheap to buy.
dsb189
Nov 11, 2009 07:13 PM
Billie
Jun 19, 2009 09:14 AM
grumpy56
Sep 4, 2008 07:37 AM
Dbl B
Jun 16, 2008 10:55 PM
12Stones
14
Mar 11, 2005 06:00 PM
