Shifter Peg
Old Sep 3, 2008 | 07:43 AM
grumpy56's Avatar
grumpy56
Default Shifter Peg
Good morning all. What is the correct way to remove the stock shifter peg on a 2006 SuperGlide? Thank you.
Old Sep 3, 2008 | 07:46 AM
Slipstrm's Avatar
Slipstrm
A pair of Vise Grips is what I used.
Once you get it broke loose it screws out pretty easy.
Old Sep 3, 2008 | 02:37 PM
Sammi's Avatar
Sammi
Vise grips worked for me, althought I did add a lot of determination - it was on pretty tight!!!
Sammi
Old Sep 3, 2008 | 07:18 PM
grumpy56's Avatar
grumpy56
Thank you both. Will break out the vise grips.
Old Sep 3, 2008 | 09:06 PM
dyna rider's Avatar
dyna rider
Default Shifter Peg
I wouldn't use vice grips. Get a set of allen sockets. They will work alot better for the pegs and you'll get alot of use out of them. A full set of torx bits is a good idea also but I just bought the bits by themselves and use them with a socket.
Old Sep 3, 2008 | 09:56 PM
timberwolfz28's Avatar
timberwolfz28
used vice grips and it took just a little force to break it loose... not much at all and this on a 6 year old bike! took the vice grips off and threaded it out by hand after that
Old Sep 4, 2008 | 06:52 AM
Sammi's Avatar
Sammi
The stock shifter peg is screwed on - it doesn't use an allen bolt for attachment.
Sammi
Old Sep 4, 2008 | 07:37 AM
dyna07custom's Avatar
dyna07custom
+1 put a rag over it if you want to save it
txrarebear
Jun 8, 2011 11:12 AM
dsb189
Nov 11, 2009 07:13 PM
Dbl B
Jun 16, 2008 10:55 PM
tom134
Oct 19, 2007 11:30 PM
12Stones
14
Mar 11, 2005 06:00 PM
