Dyna Wide Glide rear caliper change
Old Jul 9, 2014 | 03:20 PM
  #31
Jerry Pbury's Avatar
Jerry Pbury
Thanks,
I did upgrade my front master cylinder when I converted to the dual Brembo's. Figured I might need to do the same when I did the back. I'll find out tomorrow when I finish the install.
Originally Posted by jluvs2ride
I didn't when I did the front. Seems like I remember that the front only required an upgrade when going from single to dual. I guess your going from a two piston caliper to a four piston caliper but I think the MC you have is probably ok.
Old Jul 10, 2014 | 12:53 PM
  #32
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Originally Posted by Jerry Pbury
Thanks,
Be sure and let us know.
Old Jul 10, 2014 | 09:20 PM
  #33
Jerry Pbury
Works great! BTW, on my FXDC, using a rear touring brembo bracket I used 3/8" spacer between the bracket and the swingarm. I used the stock spacer (FXDC) between the wheel bearing and the bracket.
Old Jul 11, 2014 | 11:57 AM
  #34
jluvs2ride's Avatar
jluvs2ride
So, how is it compared to the OEM on that bike?
Old Jul 11, 2014 | 10:12 PM
  #35
Jerry Pbury
Smoother, more in control and less grabby.
Old Apr 27, 2018 | 09:10 AM
  #36
Kenny58's Avatar
Kenny58
Stage III
so what M/C did you end up using? I'm about to do the rear swap on my 03 wideglide.
Old Oct 1, 2019 | 10:20 PM
  #37
Frank Medina's Avatar
Frank Medina
Stage I
Originally Posted by Just Enough
I bought a Harley Brembo rear touring take off on Ebay for $80 with the mount. These are brand new take offs for trike kits. To fit a Dyna the slot in the mount needs to be filed a touch wider and you need to install a 11.8 inch touring rotor (also available barely used at very reasonable prices Craigs List or Ebay) and you need to swap the brake kine end for end. The rear Brembo really provided a stout anchor for the Dyna.
Could you provide pictures man I’m currently doing the swap and so I can’t use the stock brake line?
zimm
Oct 1, 2017 08:52 AM
fergerburger
Shovelhead
Sep 24, 2017 09:53 PM
WKNDS
Mar 8, 2014 10:12 AM
Next In Line
Wheels/Tires
Feb 1, 2014 10:46 AM
Bumpandrun
Feb 19, 2013 09:55 AM
