spark plug
Old Feb 28, 2011 | 08:06 AM
andy1411's Avatar
andy1411
2nd Gear
Default spark plug
Have an 04 low rider, after a ride yesterday plug came out while riding happened once before last year, just put back in and tightened was ok. the motor had work to increase size is it possible the correct plug could be a tiny bit bigger than one that is in there....
Old Feb 28, 2011 | 08:52 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
What plug are you using?
Old Feb 28, 2011 | 09:39 AM
bobnehoc's Avatar
bobnehoc
Something is definitely wrong....Plugs don't just fall out of the motor. I would check to see that the threads in the head are not stripped or damaged as I have never in all my 25 years of riding and 30+ years of wrenching have I heard of a sparkplug coming out and with no damage to to the threads. If the threads are damaged you can do a fix fairly simple with a spark plug thread chaser or if necessary you can get a heli coil kit to fix the problem. They are available at any good auto parts store or on line. Take a look and let us know what you find.
Old Feb 28, 2011 | 10:15 AM
Bogie1997's Avatar
Bogie1997
Wow, that thing could potentially have shot outta there like a 50 cal. Better get to the bottom of that and soon. Surprised the plug was able to rotate that many times within the boot. Live long enough you'll hear everything. Keep us posted please.
Old Feb 28, 2011 | 10:18 AM
redmonster13's Avatar
redmonster13
I would look into that a little closer. Spark plugs dont just vibrate loose and the plug wire shouldnt let it rotate that much. Something else is going on here.
Rusty Axle
Shovelhead
Apr 28, 2019 09:49 PM
ib5150
May 29, 2013 11:40 AM
dwebber
Engine Mechanical Topics
Jun 19, 2010 02:42 PM
nevil
Exhaust System Topics
Aug 2, 2008 02:54 PM
Shift_4lo
Mar 11, 2006 03:37 PM
