Shifting Problems
Old Mar 5, 2011 | 11:54 PM
Dannell53's Avatar
Dannell53
Default Shifting Problems
I just installed a new HD front foot controlls on my 09 FXD so last Saturday I was running it hard with a lot of stop and go when I started having trouble shifting the gears. Only thing I thought may be the cause was the high engine heat maybe ? After it cooled down for about 30min. everything worked fine all the way home. Wil they do that sometimes when they get hot ? There was a new lever that came with the fowards kit i didn't use because it looked just like the one that was on it (the one behind the primary cover)what do you guys think ?
Old Mar 6, 2011 | 12:03 AM
HemiOrange's Avatar
HemiOrange
Besides a possible Stage 1 upgrade, is the engine stock? Have you run it that hard before without a problem? Did you smell a burnt clutch when you stopped?
Old Mar 6, 2011 | 12:20 AM
dsiltman's Avatar
dsiltman
The lever that came with the forwards is longer than the lever that is for mids.
Old Mar 6, 2011 | 07:28 PM
Dannell53's Avatar
Dannell53
Stock engine and never done it before. No clutch smell but Maybe I do need to check the clutch adjustment ? I have 4,200 miles on it. maybe I should put that lever on also, I just thought they were the same
Old Mar 7, 2011 | 01:50 PM
mehurr's Avatar
mehurr
+1 on the clutch adjustment, not just the cable! Also, you may want to adjust your shift pawl, escpecially if youre having troubles only when up-shifting, or vice versa (downshifting). Need more info besides "hard to shift" ......
clhollister
Apr 26, 2018 08:21 AM
Big Gonzo
Aug 2, 2017 08:28 AM
sh4325
Milwaukee Eight (M8)
Apr 2, 2017 07:50 PM
dhinson907
Jul 7, 2015 06:25 PM
mikeo33y
Jun 30, 2014 11:29 AM
