Tail Light
Have you looked at the D2Moto LED taillight? I just put one on my bike a week ago $50. Not a bad light and it has a very low profile lens with built in turn signals. Installation was quick. The only issue I had with it was that it had no wiring instructions but I figured it out in a couple of minutes. I will be posting up some pics and review in a couple of days as I am finishing up some other minor mods.
Sorry going off topic here but I like your AC cover, who makes it or did you make it your self. It really goes well with the fins. Thanks for any info
Bobgv, it is made by Joker Machine. It is just the cover, originally an insert for the oval cover, but fits the round SE filter perfect. I bought the black sock from HD. Peeled off the goofy white bar and shield.
glassing it into the fender to be flush would require you to paint your fender. there is no way to polish itout wihtout ruining the finish... not sure what he was talking about... it can be done with wax paper to make it removeable but then you need to figure a way to mount it... without redoing your paint... i would sugest you do like i did on my old set up
here is my old set up (the light i used is from Dov v twin... i am told it is discontinued... but i am sure there are others out there... sent one to Snoopy today as he is goign to be getting my stock rear fender i used to have on my bike)
cover the stock hole (i used plastic and rivits) then re drill 4 holes
(was nice to have an extra set of hands/eyes when i did it. Chad helped me out)
i ditched the backplate for the light/plate and just used the frame
first we found "the spot"
then taped for the drilling
holes drilled
powder coated it black and added LED turn sigs into the mother board
all wires wrapped
done
holes drilled
all wires wrapped
done
rjheff, It was pretty easy to wire up. The whole thing was under a half an hour. There were no instructions or wiring diagram, but I figured it out very quickly. I did this to get a smaller tail light and to remove my rear signals as I had them attached to the docking kit also. I should be able to post up some pics and a How To tomorrow when I get home from work. I have all of the pin outs for the wires and there is no splicing needed.
Thanks for the info guys! Not sure what I'm gonna do. Bike is apart waiting on my rear wheel to come back from Ride Wright. Once I get it up and running, I'll make a decision on the light.
Yea, your right Joe! Is that a CycleVisions Eliminator light you installed? Was talking to Drew from Dr. V-Twin and he recommended the Cyclevision light. Not sure about the scoots though... $300+....
