Perplexed. Need input.
Old May 11, 2011 | 05:10 PM
fighthedude's Avatar
fighthedude
Default Perplexed. Need input.
The general Harley discussion is not giving me any loving so I thought I would come over to the Dyna, where my comrades won't let me down. This is a copy and paste from another thread.
Ok so long story short my bike was wrecked and in a few short weeks it will be back better than new. I have been reading and reading and searching but I have a few questions. I am installing some LED rear turn signals from Harrison Industries. I have also ordered a side mount license plate that is NON-LED. My turn signals are also going to be Run/Turn/Brake signals. That way I can have more than just the side mount when I brake. I know I will need a load equalizer. However, If I buy the run/turn/brake module does that have a built in equalizer or would I need both. If you use one of these modules on a NON-LED light will it still work? Also I am not currently using front turn signals but when i do get some the Load Equalizer should work for the front turn signals? It has probably been addressed but again the search on here is confusing. Here are the things I am looking at.
http://www.harrisonspecialties.com/m...ory_Code=MiniB,
http://www.harrisonspecialties.com/m...y_Code=MODULES
If any of you know of better stuff for less money feel free to let me know. Thanks everyone
Old May 11, 2011 | 06:32 PM
p51bombay's Avatar
p51bombay
If you are only using LED's on the front OR rear (not both) you shouldn't need a LE. I put fronts on my FXDC and they flash normally.
Old May 11, 2011 | 07:22 PM
hddan502's Avatar
hddan502
http://brightasslights.com/
I know the above are probably not cheaper, but they work great, and no need of an load equalizer.
Old May 11, 2011 | 09:11 PM
lkohan7373's Avatar
lkohan7373
You shouldn't need a load equalizer, however, if you are running a factory alarm that sometimes imterferes with the led lights. Some of the modules turn/tail/stop even have built in equalizers. But in a nutshell no you shouldn't need one and as far as halogen vs led you can mix/match without any fears. Good luck.
Old May 11, 2011 | 11:50 PM
fighthedude
ok. By factory alarm does that mean the FOB key that I need cause other than that I don't know of any factory alarm. From what it sounds like when I do buy the run turn brake module my LED and incandescent side mount license plate should work. Thanks for the info. Hope it works. Cheers
Old May 12, 2011 | 06:50 PM
fighthedude
anyone else have any advice or face similar situations?
Old May 12, 2011 | 06:52 PM
p51bombay's Avatar
p51bombay
Just install your lights - they'll work fine.
Old May 13, 2011 | 10:48 PM
lkohan7373's Avatar
lkohan7373
Yes that's what I meant by alarm. It will just throw a code but shouldn't cause any problems. Go for it.
Old May 14, 2011 | 07:30 AM
8541hog's Avatar
8541hog
Not sure on the newer bikes since some come with the RTB module, but on my 05 I did have to have a LE when only changing my rear turns to LED.
As I understand it, some if not all RTB modules have LE's in them.
vankaye
Feb 7, 2018 03:52 AM
TxFF636
Electrical/Lighting/Alarm
Jul 4, 2014 10:46 AM
fighthedude
May 11, 2011 03:25 PM
AF Chief
Jan 23, 2011 12:40 PM
TXK9
Dec 29, 2008 06:57 PM
