Need a dash
Old May 24, 2011 | 08:40 PM
georgeplg's Avatar
georgeplg
Stage IV
Default Need a dash
I own a 2002 FXD with a wide glide front end. I am changing out the tank and fenders with a wide glide set same year. I am in need of a dash that will house my electronic FXD speedometer. The key will be left where it is on the right side under the seat. So I don't need a dash with the key in it. Any suggestions for a stock dash or a long dash that will bolt up on this set up? The wide glide tank has the single bolt under the speedometer and the old FXD tank has the tewo bolts on each side of the speedometer so I can't use the old dash. Any help would be greatly appreciated.
Old May 24, 2011 | 09:04 PM
wescoot2's Avatar
wescoot2
Why not use a Stock Wide Glide Dash, and where the ignition switch would go, place another gauge or clock in its place. I'm sure with a little creativity, it could work out.
cggorman
Jul 16, 2015 03:08 PM
SmittyHDFXL
Oct 21, 2012 01:59 AM
georgeplg
Welcome Area Only
May 26, 2011 05:16 PM
dukhavguns
Apr 26, 2011 10:11 PM
harleridr
Aug 24, 2008 05:59 AM
