Front wheel problems
Old Oct 29, 2006 | 11:04 PM
lowleveldriver's Avatar
lowleveldriver
Default Front wheel problems
Hello dyna riders, I can over from the touring side to get some suggestions. A friend of mine has a low rider, and complains that in turns the front wheel is not stable. She wanted to put a wider tire on in the front. Any suggestion to improve the front wheel stability?
Old Oct 30, 2006 | 12:27 AM
GilaMonster's Avatar
GilaMonster
Default RE: Front wheel problems
she might try a SuperBrace ... stiffen up the front fork movement.
http://www.cyclesolutions.net/index....brace&id=5187F is one source
Old Oct 30, 2006 | 12:28 AM
veniculum's Avatar
veniculum
ORIGINAL: lowleveldriver
Tell her to buy an electra glide
Todd
Old Oct 30, 2006 | 12:37 AM
veniculum's Avatar
veniculum
BTW..Trey...sorry to go off the subject...but your bike is one of the nicest looking touring bikes I've seen. Really nicely done. I almost like a Road King dressed better than a classic or ultra classic.
Todd
Old Oct 30, 2006 | 05:01 AM
WdGldDave's Avatar
WdGldDave
I have a wide glide. When I changed my front tire recently, I bought an Avon Roadrunner instead of a Dunlop. I was surprised at how much more the different tire grips the road. I gained a lot more control up front with this change.
Old Oct 30, 2006 | 05:02 AM
lowleveldriver
Hey Todd thanks, and Doug thanks also. I'm going to try the brace, once again thanks
Trey
Old Oct 30, 2006 | 05:38 AM
lowleveldriver
Hey Dave was the tire the same size?
Old Oct 30, 2006 | 12:39 PM
Alaska Bobber's Avatar
Alaska Bobber
Dumlop tire is a bit "hard" for my taste. There are several out there that are better.
Also, have her check the tire pressure. Simple and probably done, but messing with the pressure just a little can yield some good results.
What exactly is it doing under pressure? Feel like it s sorta "hopping" or "soft and wobbly".
I don't have a fork brace on my Bob and at almost 300 pounds and able to hit my pipes (pic below) and axle nut on the leftside, I don't find the limit my forks. It is the stock tires.
Old Oct 30, 2006 | 01:38 PM
bobcowan's Avatar
bobcowan
She needs a Race Tech Caddies suspension kit. Best thing you can do to improve ride and handeling.
Old Oct 30, 2006 | 07:27 PM
GeorgeJ's Avatar
GeorgeJ
I bumped up the size on my front to a 110 and I think it made a world of difference, I went with metz 880's front and rear. I'm guessing a combination of size and tire compound made all the steel grate and road grooves go away. Fits snug but I like it!
[IMG]local://upfiles/15327/9CBDCD3242384284B2F2688EB9CE0577.jpg[/IMG]
