Help Help!!!
Old Nov 15, 2006 | 07:35 PM
The Bob's Avatar
The Bob
2nd Gear
Default RE: Help Help!!!
The father dropped it.
The problem im having is that the bike starts automaticly. I just pulled apart the controls and found that the ignition wires were pinched between the mounting brackets. This has caused a cut in the wire. Now to me it looks like a design problem as there is no way of pushing the wire harness all the way out when tighting the bracket to the handle bar. Has anyone seen this before?
Old Nov 15, 2006 | 07:39 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Sorry to hear it got dropped. unhook the battery and have the dealer pick it up. The griding youy hear is problly the starter
Old Nov 15, 2006 | 08:10 PM
The Bob's Avatar
The Bob
2nd Gear
Ok heres a pic of the problem, in the yellow circle is the wireing harness that is getting pinched
[IMG]local://upfiles/20839/DF5449ECE5A646FE9EA2DB47474E4EEE.jpg[/IMG]
Old Nov 15, 2006 | 08:30 PM
clayman's Avatar
clayman
On the underside of your bars there is a dimpled area that the wires rest in, you have to have them in there or it wont go back together.
Old Nov 15, 2006 | 08:40 PM
KeithB's Avatar
KeithB
Do you have collision insurance?
Old Nov 15, 2006 | 08:49 PM
grunt's Avatar
grunt
Yep I would check the wires. They most likely touching, causing an open gate condition. If you can electrical tape them apart you can limp over to get it all fixed. Otherwise trailer it over.
Old Nov 15, 2006 | 09:10 PM
PowerCobra98's Avatar
PowerCobra98
ORIGINAL: The Bob
Ok...so fix it.
Old Nov 16, 2006 | 12:25 AM
KBFXDLI's Avatar
KBFXDLI
ORIGINAL: The Bob
Well if "The Father" is your priest you are outa luck.......have it fixed at the dealer and close your eyes when they ask for your Mastercard. (God will have your back on that one for being good to one of his guys). If it's your Dad......have it fixed at the dealer and tell Dad you need a ride to pick it up and to bring his checkbook........If it's your Father in Law........kick his a$$ and then have the bike fixed at the dealer.......it will be worth the expense.
Old Nov 20, 2006 | 03:06 AM
cajunman831's Avatar
cajunman831
i would lend my wife before my harley,s....
Old Nov 20, 2006 | 03:42 AM
WdGldDave's Avatar
WdGldDave
How do you know it is getting pinched? It looks ok in the pic. You could start by loosening the switch housing on the side that fell and moving the switch hosing/grip out a bit to make sure it isn't pinched.
