FXD Mod Question
Old Nov 19, 2006 | 12:14 AM
central's Avatar
central
6th Gear
Default FXD Mod Question
I have a 1999 FXD that I am changing the front end to a stock wide glide FXDW front end and also plan on lowering the rear an inch with shorter shocks.
My question is if anyone can tell me how this is going to affect my trail. If I'm correct, the stock wide glide trees have a 3 degree rake built in and also I think the tubes are an inch or two longer than a stock FXD. I'm just trying to figure out how these three things (Lowering the rear an inch, 3 degree trees, and longer tubes) are going to affect the trail and handling. Thanks for any help.
Old Nov 19, 2006 | 08:24 AM
DAVEY's Avatar
DAVEY
Default RE: FXD Mod Question
Not all sure. i have a 2001 FXD and im told by everybody never go with the wideglide front end! they told me handeling will be bad! Lowering the rear must be done with shocks and never just brackets. Let me know how you make out,Davey
DAVEY's Avatar
DAVEY
Old Nov 19, 2006 | 11:15 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Hi Central, welcome to HDF, i thought th erake was in the head, notthe trees on the stock WG. but i don't know for sure.
Old Nov 19, 2006 | 12:18 PM
soup48's Avatar
soup48
Keithb is right, the tree is the same the head, like the Lowrider is the same. The forks are longer (maybe) because of the angle of the head. I have a FXD and I bought Lowrider rear shocks and the spring kit to lower the front forks. No problem.
Old Nov 19, 2006 | 02:03 PM
steelcowboy's Avatar
steelcowboy
Dyna frames are all the same the triple trees are different WD's typically use a 34 deg forks angle and yes the forks are longer to accomidate this.
2013superglideseattle
Jun 10, 2016 01:02 AM
USMAMule
May 10, 2016 09:48 AM
Swamphunter
Jul 17, 2011 09:05 AM
hommes
Nov 10, 2009 12:35 AM
sprinter
Apr 13, 2005 01:21 AM
