Night Modding..
Old Sep 22, 2011 | 10:02 PM
emerican19's Avatar
emerican19
Default Night Modding..
SUPER repetitive thread sorry.....working on relocating front signals, i've used "search" and cant find anything specific enough and im trying to bang this out tonight. WHERE ARE THE SIGNAL WIRE DISCONNECTS? Some say yank it out from the side, some say full tank removal...id rather not solder so i'd like to disconnect at the correct points. I follow the signal wiring down from the signals, the textured sheathing around the bundle of wires goes into the neck then appears it become the smooth sheathing which goes under the gas tank. are the disconnect points in the neck, at the opening of the tank, under the tank or somewhere else? What color are the actual wires? If i could just find them i feel like this would have been a 20 minute job... feel free to talk to me like a moron and really dumb this down, thanks.
Old Sep 22, 2011 | 11:31 PM
cmancini26's Avatar
cmancini26
They're towards the back pf the backbone easy to get to when tank and stupid black heat shield are removed I believe one set is blue and purple but I can't remember.
Ps buy the manual
Old Sep 22, 2011 | 11:33 PM
cmancini26's Avatar
cmancini26
What kinda bike btw?
Old Sep 22, 2011 | 11:34 PM
Five13's Avatar
Five13
On the two dynas 01&05 that I removed the front signals on, both of the plugs were inside of the top frame tube. You need to pull the wiring harness out of the frame and the unplug them.. easy job
Old Sep 22, 2011 | 11:52 PM
emerican19's Avatar
emerican19
sorry, 2007 street bob
Old Sep 23, 2011 | 07:58 AM
cmancini26's Avatar
cmancini26
Do you have a manual?
Old Sep 23, 2011 | 08:24 AM
mud's Avatar
mud
OK. you didn't search very hard.
been available in the Stickies for years
...............click this link
..............................posting #3
............................................wiring
you will find the connectors in the backbone,
below the front of the tank..........
07 FXDB......... should be Molex connectors (below)
(((06 used Deutsch.....https://www.hdforums.com/forum/4277701-post1093.html. )))
Molex connector poking tool.
The 06 handlebar controls used Deutsch.
In 07 they went to Molex.
Very simple to remove the wires. (pix follow)
First off you have a hook tool........
Insert the hook tool into one of the D shaped holes
and the point will aim at the other Dhole.
Above, use the tool to pull up about a quarter inch.
(you are pulling up the secondary lock)
Now, below I show a little T wrench I made up,
(for the primary lock)
using .032 stainless steel wire.......
Now, below, this is where you wanna poke your tool.
Doesn't take much, you don't need to bend anything.
Just push your tool in gently,
and pull it out the back (the wire).
All of the high performance fittings that are used these days are marked.
Whether they be AMP, Deutsch, or Molex (pictured below).
..........they are all marked...........................................
Old Sep 23, 2011 | 11:04 AM
Just Blaze's Avatar
Just Blaze
mud is 100% correct, I just removed mine (they;re listed in the classifieds with the relocation brackets).
Very easy to do, to help with space you can unbolt the tank in the front and lift it up enough to stuff a rag under it between the tank and the frame.
You can use any number of things to keep it lifted, I just used a wad of rags for cosmetic protection. The wires are black so colored wires won't help you, I just slightly pulled and pushed on the blinker wires while holding different wires under the backbone until I felt resistance and that's the one I unplugged.
mud's pic's show it all....pull down the plastic cover (first two pics) unclip the correct wire (3rd pic) and pull the wires through the frame, and you're good to go.
Old Sep 24, 2011 | 08:25 PM
emerican19's Avatar
emerican19
Can you unplug from the signal end and go backwards or is it pretty solidly attached?
Old Sep 24, 2011 | 08:52 PM
mud's Avatar
mud
or
..no ..yes.
AlexJamess
Feb 15, 2017 03:21 PM
machm1969
Nov 18, 2012 01:10 PM
Cullmanco
Electrical/Lighting/Alarm
Feb 21, 2012 06:04 AM
TheGeek
Nov 2, 2007 12:44 PM
bikerdog134
Sep 23, 2007 09:03 AM
