More starting issues
Old Sep 28, 2011 | 12:38 AM
JT-FXDL's Avatar
JT-FXDL
Default More starting issues
I've been having a starting problem for a while now and it's continually getting worse. I get home from work, shut off the bike, open my shed, and it won't start. It sounds like it's not even turning over. And it makes an awful sound trying to turn over, like when trying to start a car when already running. Eventually, it sounds better, I can hear it turning over then it starts. Starter? Solenoid? How easy a fix? Will a heavy-duty starter fix this?
Old Sep 28, 2011 | 06:52 PM
JT-FXDL's Avatar
JT-FXDL
(Bump) Anybody?
Old Sep 28, 2011 | 08:39 PM
louisianaSVT2001's Avatar
louisianaSVT2001
Starter issue?
Old Sep 28, 2011 | 09:13 PM
dsiltman's Avatar
dsiltman
I had that problem and the motor kicked back and killed the starter. Went with a drag specialties starter and have not had a problem since. Cheaper than a Harley starter as well.
Old Sep 29, 2011 | 06:18 AM
OldMike's Avatar
OldMike
You can't diagnose anything until your battery and connections are in good order.
Old Sep 29, 2011 | 08:43 AM
JohnnyC's Avatar
JohnnyC
^ 2nd that!
What ride do you have? Model / year are always important details if you'd like the right answer.
I'd even consider the solenoid isn't kicking the gear out correctly.
Old Sep 29, 2011 | 09:03 AM
JT-FXDL's Avatar
JT-FXDL
Originally Posted by JohnnyC
^ 2nd that!
It's a 2009 Low Rider, bought new 2 years ago. Python 3 slip-ons, SE air intake, & download all done within a month after purchase, has run perfectly since then. The battery cables are good, clean and tight. No exhaust leaks anywhere. Plugs and gaps look good but are stock. battery is good, use a tender to check & charge. Air cleaner is clean and I clean it each season regardless. Am I forgetting anything? Turns over fine when cold. When hot, will not turn over and I get the grinding. Have to wait a bit when hot, not good when out with friends and they all have to stand around and wait. I'd like to get this resolved so I don't damage anything else in the meantime. (flywheel?)
Old Sep 29, 2011 | 10:01 AM
07bobber's Avatar
07bobber
could be your battery, even though its only 2yrs old...
Old Sep 29, 2011 | 10:05 AM
JohnnyC's Avatar
JohnnyC
Hard hot starts usually indicate a bad starter. Worn windings and contacts in the starter can create a huge drag when warm, when going bad.
Old Sep 29, 2011 | 10:30 AM
jamman's Avatar
jamman
What Johnny C said.
