Head lite adjustment
Old Feb 3, 2012 | 09:41 AM
Griff012FLHX's Avatar
Griff012FLHX
Default Head lite adjustment
I know, buy a manual....
Well right now I don't have one.
I did this once, I just dont remember the measurments....
It's 20-25' feet from the wall and the mark on the wall is 36" above the floor.
Will someone verify this for me....
08 FXDC
Old Feb 3, 2012 | 09:51 AM
Kaycee's Avatar
Kaycee
Yep 25'/35"
Old Feb 3, 2012 | 10:00 AM
O-Town D's Avatar
O-Town D
Doing it "by the book" - with bike standing straight up on level ground and 25' away from vertical wall, center of high beam image on wall should be about 2-1/8" lower than the measurement from ground to center of headlamp bulb (see thumbnail).
Old Feb 3, 2012 | 10:03 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
To adjust the headbeam you could use the info below.
If you run aux or fog lights: switch to lowbeam and bring the aux/fog lights in line with the lowbeam.
Old Feb 3, 2012 | 10:37 AM
bikerlaw's Avatar
bikerlaw
Jeez, it must be nice to have a stock light on a stock front end at the stock height. Some of us have to actually go outside at night and point it at the road.
_______________________________
Old Feb 3, 2012 | 11:19 AM
ynots's Avatar
ynots
Rocket science 101
Old Feb 3, 2012 | 02:45 PM
Griff012FLHX
Ok head lite adjusted, well see how it is tonight.
I know I could of done it tonight, butt I didn't want to wait.
And with the fairing, it's a little easyer to know the spechs and get it close.
I did not want to have to take off and replace the fairing anymore than I had to....
Thanks for the info guys....
It was high and to the right.
Old Feb 3, 2012 | 03:14 PM
maddghost's Avatar
maddghost
You know i went by the book once but the silly light keeps shifting on me so every now and then i pull up behind a car at a stop light and tap the ****** down just low enough not to illuminate inside the vehicle ahead and it's all good!
Old Feb 3, 2012 | 05:34 PM
macnab_sf's Avatar
macnab_sf
I don't recommend doing this. I hand-pushed my light down without loosening the bolt, and ended up bending the (cheap-*** riveted mount) housing enough that the light now squeaks because it can move. I need to get in there and replace the rivets or somehow stop it from moving while vibrating.
Recommended: Loosen the light before adjusting. Then tighten it back down.
Edit: After posting this, my new osram 85/100 bulb showed up. I down to the garage and installed the bulb. Tapped some shims into the gap so the headlight won't squeak any more.
Old Feb 3, 2012 | 06:34 PM
bikerlaw's Avatar
bikerlaw
Tell us how that Osram works out. I suspect an 85/100w bulb would just blow away even my Silverstar Ultra, but it would be nice to hear first hand.
