Red Key - after install LED rearlight , and removed front indicators
Quick question. I'm having this problem. I have a custom dynamics load equalizer. I thought the key went away but when I went for my first ride it came back on. Do you have to clear the codes or did it just go away on its own? I'm gonna be pissed if this EQ doesn't do the job and I have to buy another one.
Here is something you could try that came in the instruction sheet for my Badland EQ. It said something to the effect that if you had LED's hooked up prior to adding the Load Equalizer, you must reset the TSSM system and they include the step-by-step instructions on how to do this. I did not have to do this on my bike but maybe you others with issues still do have to reset your TSSM. Try it out! Can't hurt at this point.
Just wanted to post here that I ended up finding that I pinched the clutch neutral wire when I clamped down the clutch lever clamp. I must have done it when I loosened up the clamp to re-position it. I never found answers in the threads and I wanted to document in case someone else needed it.
bradhinz
02-02-2008 08:17 AM
