Anyone running a 200???
Is there anyone running a 200 series tire on the rear of the wide glides? I have the 180 now and was wondering if I could fit a 200 without any mods. Also how much bigger in inches is the 200 over the 180? I know 20mm but what is that in inches. Thanks Guys
All I know is that the street bobs have a 4.5" rim standard and this is below the specified minimum rim width for a 200mm tire. You need a 5.5" minimum, 5.75" or 6.00" ok too.
Having said that I don't know what rim the Widey has standard. I thought it was still the 4.5" rim with the screaming eagle 180 which has a different bead design or something that allows it to be fitted to the 4.5 rim.
Someone with a Widey will have to answer that one
2011 Harley-Davidson FXDWG Dyna Wide Glide - USA Specifications
U.S. MSRP - Vivid Black $14,499. Two-Tones $15,194 (with Flames)
CHASSIS
Frame Mild steel, tubular frame; rectangular section backbone; stamped, cast, and forged junctions; forged fender supports; MIG welded
Swingarm Mild steel, rectangular tube sections, stamped junctions; MIG welded
Front Forks 49 mm with polished aluminum fork triple clamp and dual-rate springs
Rear Shocks Coil-over shock
Wheels5: Black, Laced Steel
- Front 21 in. x 2.15 in. (533 mm x 55 mm)
- Rear 17 in. x 4.5 in. (432 mm x 114 mm)
this pic is on a stock wide glide rear rim?
CHASSIS
