HELP: Slashed Wire while installing bars- bike won't start!
Old Feb 13, 2012 | 09:54 AM
Tundra bob's Avatar
Tundra bob
Originally Posted by Dingobob
Check fuses mate. If you've shorted you've probably blown fuses so bike won't start.
Before you do anything else, repair those wires. Then check your fuses, battery etc.
Old Feb 13, 2012 | 10:24 AM
EricInNCa's Avatar
EricInNCa
Yeah dude, you gotta fix that wiring before you try riding. As mentioned, probably a dead short and blown fuse on you bike...I also find it interesting that you're OK with the front signal working but aren't worried that the headlight doesn't... Take that mess apart and do it right. Wire it internally, solder (and heat shrink) any connections. I'm not trying to be a *ick, but it's kinda important that all that stuff works right over the long haul...
Old Feb 13, 2012 | 10:34 AM
River_123's Avatar
River_123
blank
Last edited by River_123; Feb 13, 2012 at 11:17 AM. Reason: people are set in their ways.
Old Feb 13, 2012 | 11:11 AM
ek1's Avatar
ek1
Originally Posted by SC-Longhair
You're saying in a vibration, jolting situation crimps are stronger than a *good* solder joint? C'mon.
I would say a solder joint and quality heat shrink over the joint would be the best because it would help seal the joint from moisture.
++1 on this fix. Solder and forgetaboutit.
Old Feb 13, 2012 | 11:21 AM
JohnC FXDX's Avatar
JohnC FXDX
Originally Posted by River_123
blank
Being an Electrician vs. auto, marine or motorcycle wiring is a big difference. Houses don't move and vibrate. I've been a Contractor for over 20 years and know all about residential and commercial electrical. I have had plenty of wire nuts not holding and being the source of an outlet or switch not working. Soldering doesn't make sense in your field. If a solder joint is done properly and heat shrink is used over it, you can't go wrong.
Old Feb 13, 2012 | 11:24 AM
JohnC FXDX's Avatar
JohnC FXDX
Originally Posted by staplek
Well,
My intentions were to install my new Todd Cycle 10" Strip apes on my '06 Bob. Early on I decided that conquering the internal wiring seemed ambitious for the 2 hours I had to do with my help (neither of us had done this before). So we decided to keep wiring external for time being. Problem is we didn't realize that it was not possible due to lack of recess under bottom of bars to accommodate electrical wire thickness by housings. As a result, as we tightened the housing, the sharp edge where internal wires enter the bars actually sliced into the wire wrap and cut 3 wires clean through on left side. It turns out that the headlight will not turn on but left turn signal will. I was feeling ok with that until I tried to fire up the bike and it would not turn over. Electrical started flashing (almost like fighting for battery) and sound like little gunshots.
Can anybody help me shed some light on this? I'm not surpised the headlight didn't work but I expected it to start as nothing on the right housing throttle side seemed to be compromised (unless i missed it).
thanks for any advice
If you are not doing internally wired and there are no dimples on the bars, you can cut a small notch in the controls so it does not pinch the wires. This is actually better to do because dimples compromise bar shape and structure. I saw it listed somewhere on Biltwell's site. There was a video posted for it.
Old Feb 13, 2012 | 11:34 AM
JonV's Avatar
JonV
What he said.....
Old Feb 13, 2012 | 01:13 PM
River_123's Avatar
River_123
Solder joint fatigue is well documented in anything from cars to the space shuttle. Cyclical vibrations break them down and cause them to become brittle. Anybody that wants to know more can PM me. I'm not going to argue, I have 4 years technical training.
Old Feb 13, 2012 | 01:53 PM
BiggDogg's Avatar
BiggDogg
no headlight was just ok because a custom shop is a couple blocks away and we were gonna say "F it" and take it to them to fix.
But now we are intrigued and the weather doesn't seem to be getting warmer so we will just cut them all and internally wire and re-solder and fix the blown fuse and call it a day.
yea I'm hijacking my cousins thread
Old Feb 13, 2012 | 01:58 PM
dpk20x's Avatar
dpk20x
No need to cut them all you should be able to pull the wires from the connectors with a simple pick tool
