HELP: Slashed Wire while installing bars- bike won't start!
Old Feb 13, 2012 | 02:08 PM
SIDECAR BOB's Avatar
SIDECAR BOB
Originally Posted by River_123
Solder joint fatigue is well documented in anything from cars to the space shuttle. Cyclical vibrations break them down and cause them to become brittle. Anybody that wants to know more can PM me. I'm not going to argue, I have 4 years technical training.
Have also been seeing more and more about solder joints not holding up well in a high vibration environment. I have always thought solder heatshrink method was the best but with the new evidence and the introduction on high quality crimp on connections with included sealer is causing me to rethink that too, cant say I have had any problems with either when done properly.
Old Feb 13, 2012 | 03:58 PM
JohnC FXDX's Avatar
JohnC FXDX
If the solder joint is a wire to a fixed and mounted item, like a circuit board, then yes vibration could cause it to break. When you are talking about two lengths of wire that have flexibility to move, no. I just soldered my handlebar wiring today. When it is done right, the solder will get sucked into the threads of the wire and even up into the jacket. Pretty much have to cut it to get that apart. I would bet a crimp could be pulled apart. A crimp also does not give the best connection as far as surface area. Guaranteed that all wire surfaces aren't connected to one another on a crimp. I don't have 4 years technical training, but I have over 24 years of training in different technical fields. Even had ASE certification in auto mechanics.
viperpit07
Nov 26, 2019 05:04 PM
Jarheadexpress
Electrical/Lighting/Alarm
Nov 1, 2017 12:25 AM
bigmant
Mar 24, 2015 09:55 PM
UncleChey
Feb 14, 2011 04:31 PM
bajabob
Feb 3, 2006 11:55 AM
