New bars, now electrical issues
Old Aug 16, 2014 | 08:57 AM
viperpit07's Avatar
viperpit07
Default New bars, now electrical issues
Installed some WG bars with internal wiring on my bike last weekend and im starting to have an issue with my left blinker and im wondering if anyone could shed some light on this for me.
I clipped my wires when i did the internal wiring, did it all myself. soldered them and used heatshrink tubing on all of them, then wrapped them in electrical tape.
Now the issue I am having. yesterday when I was riding my left blinker started flashing and it wouldn't shut off. (spontaneously it came on) so i pulled in the clutch turned off the bike and started it back up and it was off for about 1/4 of a mile and then it came on again. wiggled my wires by where i soldered them and then the blinker didn't work at all. played with the wires some more and now it works. but twice since then i have had my blinker turn on and olny wiggling the wires will make it stop and then its fine. Why will it start blinking and not stop? is the connection on one of my wires bad? Thanks
Old Aug 16, 2014 | 09:32 AM
CACruiserHD's Avatar
CACruiserHD
The fact that you wiggled the wires where you soldered them tells the story. You need to make sure your solder job is correct. A lot of people just gloop on solder but thats not going to last. Check on youtube for soldering if you aren't sure how good your solders are. The only other thing that comes to mind is a pinched wire.
What's weird is they came on instead of blowing a fuse. Makes me wonder if your running light wire is somehow touching the blinker wire.
The other thing to do is stagger the cuts so they aren't side by side.
Here's a video on soldering that explains it well (unless you are sure they are perfectly fine). I was doing it wrong for years and now my solders are so strong i can't pull them apart.
Old Aug 16, 2014 | 10:37 AM
viperpit07's Avatar
viperpit07
I had my dad who is an electrician help me solder them so im boggled that wiggling the wires fixes it. plus they are all seperately heat shrunk. so I was wondering if maybe a harelys default if there is a bad connection is for the blinker to stay on...
Old Aug 16, 2014 | 10:43 AM
skinman13's Avatar
skinman13
A pretty typical reason for this kind of problem is that when you soldered the wires, you left a sharp peak in the solder when you pulled the iron away or you have a stray wire sticking out which will eventually poke through the heat-shrink tubing. Look at the how-to video and you can see he leaves the ends of the wire sticking up and these ends will quickly poke through the heat-shrink and short out to adjacent wires or to ground. His technique is solid with the exception of leaving those ends sticking out.
Old Aug 16, 2014 | 12:41 PM
dyna rider's Avatar
dyna rider
Default Pinched Wire
You have a pinched wire somewhere in the handlebars and it doesn't have to be at a solder joint.
Old Nov 26, 2019 | 09:22 AM
MarkLendiz's Avatar
MarkLendiz
Stage I
Replace the wire from the handlebars with the help of an electrician.
Old Nov 26, 2019 | 11:11 AM
Jay Guild's Avatar
Jay Guild
That's why I use crimping junctions for wires https://www.elecdirect.com/crimp-wir...4aAs1yEALw_wcB Solder joints are prone to cracking and possible bad flow when done to junction multiple wires together. Soldering should really only be done to non-pliable surfaces like connector ends, PCBs, and headers.
Old Nov 26, 2019 | 05:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Nice stupid first post (probably not a real person, just some spam bot).
medicmouse
Electrical/Lighting/Alarm
Aug 2, 2017 09:46 AM
TylerBoehm
Jun 11, 2014 02:14 AM
flhxmc
Mar 7, 2013 03:05 PM
Mark98012
May 1, 2012 01:56 PM
georgiabiker
Mar 19, 2008 06:57 PM
