fork leaking
Old Mar 11, 2012 | 06:00 PM
brown dawg's Avatar
brown dawg
Default fork leaking
got my front end back together after powder coating the lowers and insalling chrome fork tubes all is fine except for my left fork is leaking a little more fluid than it should i know a little weepage is alright but this seems a little excessive any ideas
Old Mar 11, 2012 | 06:11 PM
AFMM3's Avatar
AFMM3
When you filled with oil, were the tubes compressed completely during measurement? Maybe overfilled?
Old Mar 11, 2012 | 06:44 PM
brown dawg's Avatar
brown dawg
measured the exact same amount of fluid for both sides also my left side fork was a little off from right side in clamp (measurement from tube cap to top of triple tree) got them both the same would 3/16 matter though
Old Mar 11, 2012 | 08:13 PM
DaveCarlson's Avatar
DaveCarlson
Did you put new seals in? Easy to nick seals if you don't put tape on some of the parts as you slide the fork tubes in.
Old Mar 11, 2012 | 08:39 PM
bobnehoc's Avatar
bobnehoc
If you did change thd seals, that would be my vote. The seal must be pressed in squarely. If it goes in cocked at all they can leak. The best way to install the seal is with a 2" pvc pipe unless you ownn or have access to the HD tool. Is far a.s the tubes go they should both be at the same height. As far as fluid goes my 07 is not filled by ounces but by measuring the height of it as per the manual. I would probably verify that you have the correct amount of fluid and if so the seal is no good. Good luck and let us know what you find.
Old Mar 11, 2012 | 10:20 PM
brown dawg's Avatar
brown dawg
put new seals in w/the pvc filled fork oil as specified in manual one way or another ill get it squared away thanks for the input
JWCFatboy
Dec 8, 2018 12:30 PM
joe40x
Sep 4, 2018 10:54 AM
karlkcfi
Apr 1, 2012 03:42 PM
vladt
May 25, 2010 04:22 AM
DWhite
Apr 22, 2008 03:52 PM
