Fork seals
Old Sep 4, 2018 | 09:33 AM
joe40x's Avatar
joe40x
Angry Fork seals
I rebuilt a set of 49mm forks and somehow screwed up the one seal. It's not a gusher, but it weeps a bit more than i would like, Checked for dirt and tube scratches and found nothing. Is there any way to just remove the leg and hook the seal out without an oil bath, or do I have to do a total disassembly? 2013 fxdwg if that matters.
Old Sep 4, 2018 | 10:54 AM
Cygnusx51's Avatar
Cygnusx51
I’m guessing you’ll do more damage trying to get the seal out without using the fork and fork slider as a slide hammer to get it out. The tolerances are pretty tight and you’d most likely only be able to use small pick tools to try and grab the seal, probably tearing it. Then again, I’ve never tried doing without a full disassembly.
JWCFatboy
Dec 8, 2018 12:30 PM
karlkcfi
Apr 1, 2012 03:42 PM
brown dawg
Mar 11, 2012 10:20 PM
DWhite
Apr 22, 2008 03:52 PM
billnourse
Oct 9, 2005 12:50 PM
