hornless
Old Dec 23, 2006 | 07:22 PM
mud's Avatar
mud
Default hornless
Really cleans up "the otherside" of the motor. Gotta chop that thang off soon.
Need to find an alternate location, cause I do want to have the device available when it is needed.
Anybody gone this route??
Is yours still on the workbench Formula?? You are pretty damn good at problem solving.
Reminded me when I saw your pix in the batttender thread, and the little clip on the wire
to the front plug caught my eye. What'd you do there?? Looks real clean.
Nice setup on the batttender as well.
mud
Old Dec 23, 2006 | 07:27 PM
Hey Joe's Avatar
Hey Joe
Default RE: hornless
Old Dec 23, 2006 | 07:43 PM
Hey Joe's Avatar
Hey Joe
Old Dec 23, 2006 | 09:14 PM
Shrug's Avatar
Shrug
I've been thinking the same thing since I saw the "bare jugs" post a few weeks ago. I think the horn is about the least attractive part of the bike. It just seems out of place. Also, I plan toinstallfinned headbolt bridges next week and I'd like that area as open as possible.
The hole on the downtubes is for the upper crash bar mount, which I already have. I'll have to get creative and configfure a mount that looks clean and professional. I'm open to suggestions if anyone has some. Will post pics when it's completed.
Old Dec 23, 2006 | 09:41 PM
mud's Avatar
mud
ORIGINAL: Hey Joe
I just went out and looked at mine closer I think it would just bolt
right up there is already a hole.
Only thing to do would be reroute the wires
maybe splice them if they wernt long enough.
Hey give it a "shot" Joe.
(where you goin with that gun in your hand??)
I think the stock horn hung on the downtubes would look like sh it.
On the other hand, may not.
mud
Old Dec 23, 2006 | 10:32 PM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: mudpuddle
mud
Mud,[/align]Mine's still on the work bench, I did try and fit it behind the battery but it seemed a little too tight. Behind rear engine mount, it sticks out too far. So looks like the best place will be just below the voltage regulator using a strip of metal as a bracket andmounting tothe engine mount to frame bolts. Solder wires to the terminals,shrink sleeve it,and tie wrap the wires to the harness bundle that runs down the frame on the right side of the bike all the way up behind the battery. I already redressed the original hornharness to behind the battery.[/align][/align]My ignition wire supports are homemade, the front cylinder wire is supported with Romex house wire that I formed using a Phillips screw driver shaft as a mandrel, installed it on the bracket then bent the two loops open put the ignition lead in and closed the loops without putting anypressure on the ignition lead. The rear lead support is a flat piece of plastic that I cut to size and used a soldering iron to punch two holes thru for thetie wraps.[/align][/align][/align]
Old Dec 24, 2006 | 12:13 AM
CraigC's Avatar
CraigC
I'm still really happy with how my horn project turned out.
https://www.hdforums.com/m_991508/tm.htm
Old Dec 24, 2006 | 12:37 AM
mud's Avatar
mud
ORIGINAL: WS6 Formula
Thanx for the info ponyman.
I thought somethin looked different about the two gang wire support, couldn't tell from that other pic.
What camera are you shootin with, nice shots.
Great job, keep up the good work.
mud
Old Dec 24, 2006 | 12:40 AM
mud's Avatar
mud
ORIGINAL: CraigC
Very nice job CC. What horn is it?? An HD item??
Thorough description there at the other thread.
Thanx for pointing that out.
Your attention to detail is to be admired.
mud
gleam
Aug 13, 2019 08:12 AM
Gitarded
Jan 31, 2012 12:02 PM
socal yankee
Air Suspensions
27
Aug 15, 2011 08:56 AM
ngoti8tor
General Topics/Tech Tips
Jun 14, 2009 07:16 AM
