What did I do wrong - Clutch
Old May 14, 2012 | 02:13 PM
LINZ FDXF's Avatar
LINZ FDXF
6th Gear
I did everything as suggested but nothing changed. Maybe this was like this before I tore it down to install the big bore kit and never noticed. I fired up the bike and rode it. All shifting seemed okay. I still don't understand why it doesn't freeroll when in gear with the clutch lever pulled in. I'd again like to thank everyone for your replies. It's great to have somewhere to go when you need a little help.
Linz
Old May 14, 2012 | 02:51 PM
mattVA's Avatar
mattVA
Linz
It's a wet clutch. With cold oil in between the plates the clutch will drag. It will roll but it'll take a lot of effort. Either put it in neutral or turn it on and it'll move without effort.
Old May 14, 2012 | 06:39 PM
LINZ FDXF's Avatar
LINZ FDXF
6th Gear
Yes. Was easier to roll in gear when it was hot. Just probably never noticed it before. Was getting ready to fire it up for first time after winter rebuild and just looking to make sure everything was okay. Thanks again, on to newer problems now.
Old Jul 5, 2012 | 07:53 PM
kiethf's Avatar
kiethf
Originally Posted by Stiggy
When you have the actuation cover off, you need to make certain that you pull all the slack out of the cable from down there, inside the cover. This points the ramps lever down towards the floor.
This puts the ramp where it needs to be when the cover is reinstalled with the 3 ***** in place.
Stiggy how tricky is this task i think i've got this problem...clutch adjustment and clutch is not engaging after tightening cable adjuster.... I am worried about getting out of depth. Thanks.
Old Jul 6, 2012 | 04:43 AM
J.Sizer's Avatar
J.Sizer
You beat me to it...+1
Old Jul 6, 2012 | 07:09 AM
kiethf's Avatar
kiethf
You or someone pulled the clutch lever during the spring install. You "flipped" the 3 ball ramp on the RIGHT side of the bike, where the cable goes in.
You'll have to pull that clutch actuation cover off and put the ramp back down to 6'OClock and reinstall the cover.
Then you can adjust the clutch on the left side, then the cable at the adjuster.
Common mistake....
Stiggy will i be able to put the ramp back to 6 oclock without removing the reatainer spring? Thanks.
Old Jul 6, 2012 | 10:01 AM
SURFOR Chop's Avatar
SURFOR Chop
You should be able to ... the pressure from the clutch spring (on the opposite side of the bike) is what keeps the ramp in position ...
Old Jul 6, 2012 | 10:27 AM
jshull's Avatar
jshull
why the hell was the ramp out to put in a clutch spring? it WILL NOT work move when pulled in, roll to any dealer and try it...wet clutch...
Old Jul 6, 2012 | 11:29 AM
07bobber's Avatar
07bobber
this happend to my buddys dyna when he did his bar swap, the clutch was cold and sticking from adjusting it all.....it was fine after starting it....
Old Jul 6, 2012 | 01:49 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Not to bust any one's chops but, I didn't go to MMI to work on HD's, but I think the picture of the the clutch release cover is upside down. First clue, the dipsick, it usually comes in from the top.
