What did I do wrong - Clutch
Old May 12, 2012 | 03:14 PM
LINZ FDXF's Avatar
LINZ FDXF
6th Gear
Default What did I do wrong - Clutch
I installed a 103ci big bore kit on my 09 Fatbob. I installed the heavy duty clutch diaphram spring that came with the kit. I also adjusted the clutch as per the manual. With the engine off, the bike will not roll with the clutch disengaged. (lever pulled). It rolls easily when in neutral. When in gear it will not roll freely whether you hold or release the clutch lever. It seems to make no difference. When in gear it is still turning the engine over with the lever pulled in. Any ideas on what I may have done wrong or how I can fix this.
Thanks
Old May 12, 2012 | 03:23 PM
jcmusic's Avatar
jcmusic
Thanks
Sounds like the clutch is not engaging.
Old May 12, 2012 | 04:04 PM
dyna rider's Avatar
dyna rider
Default Clutch Adjustment
When you are running the adjustment shaft in, ANY resistance you feel is where you stop and back it off 1/2 turn. Then lock it down with the jam nut.
Make sure you do this when the bike is stone cold otherwise it won't adjust correctly.
Tighten the cable up per the manual.
Old May 12, 2012 | 06:22 PM
Wireguided's Avatar
Wireguided
Disengaging ??
Old May 12, 2012 | 06:28 PM
Stiggy's Avatar
Stiggy
You or someone pulled the clutch lever during the spring install. You "flipped" the 3 ball ramp on the RIGHT side of the bike, where the cable goes in.
You'll have to pull that clutch actuation cover off and put the ramp back down to 6'OClock and reinstall the cover.
Then you can adjust the clutch on the left side, then the cable at the adjuster.
Common mistake....
Old May 12, 2012 | 06:56 PM
maddghost's Avatar
maddghost
Shrewd man, peace out!
One thing I can ask you LINZ , you did the clutch adjustment with the cable quite loose and the bike cold right? But was the clutch cable maybe stuck out and caught by the aluminum tip of the outer cable? because I did that once. In that case you only have to loosen the cable and and start over making sure the end of the outer clutch cable is well seated in the clutch lever assy.
Old May 13, 2012 | 12:04 AM
LINZ FDXF's Avatar
LINZ FDXF
6th Gear
Thanks for the replies. I readjusted it at least a half dozen times with no change. I did as Stiggy suggested and pulled the cover on the right side. Everything looked ok but I took it all apart and reassembled it anyway. I'm not sure what Stiggy meant by "flipped". Nothing looks like it can go anywhere it shouldn't be. Adjusted the clutch again after reassembling but still get the same result. With the engine off, rolls back and forth easy when in neutral. Put it in gear and it won't roll whether cluch lever is held in or not. I put it in 6th gear and can move it but very hard still. Removed plugs, held in clutch lever and rolled bike forward in 6th gear. Definately still turning over engine. I really don't know what to do now short of having to take it to the Dealer. I'm open to any other suggestions. Thanks to all for your time.
Linz
Old May 13, 2012 | 01:31 AM
ynots's Avatar
ynots
When my bike sits over night I cant pull the clutch in and push the bike when its in gear. I always put it in neutral, pull the clutch in and start it... then put it in gear and go. My clutch has been adjusted by my indy and myself, its just something its always done
Old May 13, 2012 | 01:36 AM
SURFOR Chop's Avatar
SURFOR Chop
The potential issue that Stiggy was alerting you to is if the tab on the inner ramp is not pointing up (or down as in the photo--which is upside down) ... it can sometimes be pointed toward the side where the cable comes into the cover when the '***** ramp over' ...
If it does this and the tab is oriented toward the cable, it will reduce the pull on the cable to nil ... and if the clutch is adjusted to engage, it will not allow the clutch lever to pull and disengage the clutch ...
This may or may not be your problem ... but, by ensuring the proper orientation of the tab on the inner ramp, you can eliminate that as a possible source of your problem ...
Good luck tracking down the problem and fixing it ...
R/
'Chop
Old May 13, 2012 | 04:08 AM
Stiggy's Avatar
Stiggy
Common mistake....
When you have the actuation cover off, you need to make certain that you pull all the slack out of the cable from down there, inside the cover. This points the ramps lever down towards the floor.
This puts the ramp where it needs to be when the cover is reinstalled with the 3 ***** in place.
