primary noise?
Old May 25, 2012 | 08:03 PM
brown dawg's Avatar
brown dawg
Default primary noise?
i know noises are hard to track down but here goes 09 fxdc noise sounds like its coming from primary upon hard high rpm acel (in neu rev it up and no noise) sounds like heat shield pinging or tinkin shifts fine no clutch slipping amsoil syn filled to correct level only happens when im really gettin on it when fluid changed 800 mi ago no metal on drain plug
Old May 25, 2012 | 10:05 PM
hedgehorn's Avatar
hedgehorn
sounds like pinging to me. I had the same thing on my electra glide. You been buying your gas at the same place?
Old May 25, 2012 | 10:11 PM
07bobber's Avatar
07bobber
are you lugging the motor...or are you in higher rpm's
Old May 25, 2012 | 10:34 PM
brown dawg's Avatar
brown dawg
i was wondering if that could be it also since it does not make the noise when its not under a load or sitting still since the chain is always spinning i would think if something was wrong in the primary it would make noise all the time i always put shell 93 octane in her put new plugs in over the winter (maybe gapped wrong?) also added those chrome covers over the plugs (maybe cuasing excessive heat on the plug?) besides checking my plugs should i add octane booster to see if that remedies it
Old May 25, 2012 | 10:36 PM
brown dawg's Avatar
brown dawg
higher rpms wont do it if i lug the motor dont know the exact rpm but its pretty high
Old May 25, 2012 | 10:39 PM
brown dawg's Avatar
brown dawg
it might not be coming from the primary but it sure is coming from that side of bike kinda hard to tell were the noise is coming from when im ridin down the road
Old May 25, 2012 | 11:02 PM
07bobber's Avatar
07bobber
how many miles on your bike? could be a cam chain tensior worn down...
Old May 26, 2012 | 06:04 PM
brown dawg's Avatar
brown dawg
around 14000 mi noise is definitley coming from left side
Old May 27, 2012 | 05:13 AM
1HD1C's Avatar
1HD1C
friend of mine with an 08 had a similar noise, at idle it was there under load
it would disappear pulled it apart and found the primary chain sprocket bolt
had loosened up.
retorqued to specs and all is good. only cost the price of a gasket to check it out
Old May 28, 2012 | 01:10 PM
brown dawg's Avatar
brown dawg
had loosened up.
my noise is not there at idle, happens when motor is under load
Abandoned
Aug 18, 2013 02:57 PM
Bowhunter61
Aug 12, 2013 11:16 PM
brown dawg
May 28, 2012 01:30 PM
Rodman11
May 25, 2011 10:11 PM
Wide Glide Ride
Jan 23, 2011 11:51 AM
