Gauge Lights
Old Jun 22, 2012 | 11:53 AM
Aylor70's Avatar
Aylor70
Default Gauge Lights
On my speedometer, every now and then a green light will light up that almost looks like a G, so I'm wondering if someone has a list of what all the lights on the speedometer mean. Most I think I can figure out, but this one has me stumped. I can't seem to find it anywhere either. Thanks.
Old Jun 22, 2012 | 11:54 AM
Puffdaddy's Avatar
Puffdaddy
It is actually a 6, for indicating you are in top gear.
Old Jun 22, 2012 | 11:55 AM
nevil's Avatar
nevil
6th gear indicator?
Old Jun 22, 2012 | 12:09 PM
Aylor70's Avatar
Aylor70
Its a 6th gear indicator? Then something is wrong because I know I am not in 6th gear going 30 around town.
Old Jun 22, 2012 | 12:31 PM
nevil's Avatar
nevil
I can't think of anything else that resembles a green G but I have an 07 and things could be changed. Check your owner's manual, it shows the location of all the warning lights. I don't know about your tuner but the TMax lets you change the final drive ratio number in case the 6 gear light won't work after some drivetrain mods.
Old Jun 22, 2012 | 12:58 PM
FXDWG12's Avatar
FXDWG12
It means: G0 Faster!. But I'm just guessing.
Old Jun 22, 2012 | 06:06 PM
DCLXVI's Avatar
DCLXVI
It's the 6th gear indicator. The system works by calculating engine rpm and rear wheel speed to assume that you are in 6th gear and turn on the light. There may be times, especially when downshifting, that those rpm's match and the light comes on, only momentarily though.
Old Jun 22, 2012 | 07:55 PM
rooti's Avatar
rooti
That makes sense...I thought I've seen it flash out of the corner of my eye
hdoilcan
Apr 3, 2019 02:20 PM
HardRider06
Sep 26, 2016 10:37 AM
UltraBlack12
Apr 30, 2013 01:21 PM
Nextbite821
Electrical/Lighting/Alarm
Mar 3, 2013 05:28 PM
razzm1959
Jun 24, 2009 10:17 AM
