more help
Old Jul 5, 2012 | 11:17 PM
shane4585's Avatar
shane4585
Default more help
im looking for stock length performance springs for my front end, i dont want it lowered at all, just something a little stiffer/performance oriented. whats the best?
Old Dec 18, 2012 | 09:09 PM
shane4585's Avatar
shane4585
help!
Old Dec 19, 2012 | 12:13 AM
XFXDX's Avatar
XFXDX
Goggle searches are cool!
Hell, a search on this site should net a few dozen options for ya. No?
Old Dec 19, 2012 | 12:31 AM
Bo_Jangles's Avatar
Bo_Jangles
Race tech, ricor, traxxion. All are about 120 or so.
Old Dec 19, 2012 | 01:38 AM
ynots's Avatar
ynots
i picked up some standard length progressive springs for 70.00 shipped. cured front end dive and bottoming out
Old Dec 19, 2012 | 09:10 AM
HDCustomFabrication's Avatar
HDCustomFabrication
You have a couple other inexpensive options as well, you can add a little length to the spacer in the fork tubes that adds preload to the springs...Or, you can try a slightly heavier fork oil.
Make sure you thoroughly clean out the sliders and tubes when you have them apart.
Old Dec 19, 2012 | 04:28 PM
shane4585's Avatar
shane4585
i did a clean out and heavier oil, helped a little. but not much. my old bike didnt have these weird pipe like things inside the tubes. what are they? they look like a piece of exhaust pipe inside the legs.
Old Dec 19, 2012 | 05:06 PM
HDCustomFabrication
Those are the preload spacers, you can vary the length to increase or decrease preload on the springs, but I would not change more than 1/4" at a time. Don't over do it though, about 1/2" is really the most you should add if that much.
You can use PVC pipes for those as well.
Old Dec 19, 2012 | 05:32 PM
rooti's Avatar
rooti
What exactly are you trying to correct? Heavy fork oil might help with brake dive but will slow down your dampening...not the best thing for handling. You already have a progressive spring in your stock harley forks.
I put the ricor intimidators in a noticed a big difference but I still think I can get it better.
Stiffer and performance oriented are kinda going in opposite directions from each other.
Old Dec 20, 2012 | 07:28 PM
shane4585's Avatar
shane4585
ok. i dont want the front to dive when i brake, and i dont want to bottom out or feel like im bottoming out over bumps and potholes. i can almost bottom out the front end just by pushing down on the handlebars. i hate it.
