Brake problems
Old Jul 8, 2012 | 02:38 AM
fatkidfrank's Avatar
fatkidfrank
5th Gear
Default Brake problems
I just recently purchased my 97 super glide. I changed the oil and took it for a ride. Once I got back I noticed that when trying to walk the bike it started to make a squeaking similar to bad brake pads. I've taken look at the brakes and it looks like the front brake is stuck.
I'm new to all this so Im looking for some guidance. Is it possible I need to bleed the piston? change all the brake fluid? or is this a bigger problem.
Just for an idea I purchased the bike from its second owner who only put on 1000 miles in 5 years. Im not sure what maintenance was done over those 5 years but I'm not guessing much.
Old Jul 8, 2012 | 04:10 AM
Foxster's Avatar
Foxster
Could be just the pads are glazed and roughening them with some sandpaper will fix it.
Otherwise, could be a piston sticking. You could try getting some WD40 on the piston and then pushing it in with a thick screwdriver and pumping it back out again. Failing that, its a rebuild job with new seals.
Old Jul 8, 2012 | 09:29 AM
HD Dooley's Avatar
HD Dooley
foxster, if the pads are glazed why would they stick?
Old Jul 8, 2012 | 09:44 AM
Foxster's Avatar
Foxster
I mean, they could have become partially coated with some crud.
Old Jul 8, 2012 | 09:53 AM
HD Dooley's Avatar
HD Dooley
Gotcha
Old Jul 8, 2012 | 10:43 AM
misfitJason's Avatar
misfitJason
If it does it occasionally (like in one spot every rotation of the wheel) it is not uncommon that a rotor become warped. More than likely it is a brake pad issue or if the pads are really thick like brand new ones maybe the piston wasn't pushed all the way back in
Old Jul 8, 2012 | 10:29 PM
marines267's Avatar
marines267
Don't use wd-40 it is bad for rubber use triflow
MotoArts
May 9, 2019 07:15 PM
Chuck1
Jun 23, 2017 12:36 AM
Bobino
Apr 9, 2011 12:01 PM
SecondChance!!
Mar 23, 2009 09:57 AM
booboo
May 19, 2008 04:43 PM
