Engine heat?
Old Jul 12, 2012 | 09:23 AM
jpooch00's Avatar
jpooch00
Question Engine heat?
I don't see nearly as many complaints about engine heat on the Dyna forum as I do over on the touring bike forum. Is the seating position and engine, pipes etc. placement different enough on the Dynas that the engine heat doesn't affect the rider as much?
I have a '94 Dyna and have never felt any noticeable engine heat at all. Is that kinda true on the new ones too?
If I end up buying one, it will be left factory-stock, so that would be the configuration I'm asking about.
Many thanks in advance for any and all info and opinions.
Y'all ride safe.
Old Jul 12, 2012 | 10:56 AM
RAWHIDE07's Avatar
RAWHIDE07
Less garbage on a dyna = more airflow. The newer ones do have more heat due to the bigger motors but you can add XIED's or a tuner which helps a lot.
Old Jul 12, 2012 | 11:33 AM
perryross's Avatar
perryross
The biggest culprit on newer bikes would be the Catalytic Converters.
I got rid of mine with a new exhaust system, no more problem, 100%
improvement.
Old Jul 12, 2012 | 11:45 AM
BobJJ's Avatar
BobJJ
Stage II
I have heat problem with my '10 it comes from windshield and lowers, screaming eagle air cleaner helps. Sucks the heat back in the motor. In town like Sturgis ralley is real bad.
Old Jul 12, 2012 | 05:28 PM
jpooch00's Avatar
jpooch00
I just want to thank everybody for their responses so far.
This is exactly the kind of info I was needing. If these bikes aren't really comfortable to ride heat-wise right out of the box, then I'll pass. No way I'm spending a penny more for aftermarket parts to be able to ride it. IMO, that's total BS.
I'll keep my '94 and be happy with that instead. 60+ MPG and runs cool and stone reliable.
Thanks again for the help and ride safe.
Old Jul 12, 2012 | 06:15 PM
maddghost's Avatar
maddghost
Topic nailed by Rawhide! All those fairings are comfy wind reducers for the riders, but also serve to enclose them in the heat of the engine as well.
Old Jul 12, 2012 | 06:38 PM
jpooch00's Avatar
jpooch00
Just so there's no confusion, I was asking about engine heat issues on STOCK bikes - as in non-modified - like they come form the factory. My preference if I get one at all is the Super Glide Custom (which I forgot to mention in my original post - oops!).
If anybody has one that's been left factory-stock, I'd really be interested in hearing your opinions. But again, everybody's opinions and impressions are more than welcome and very much appreciated!
Old Jul 12, 2012 | 07:00 PM
hd2012's Avatar
hd2012
I have a 2012 FXDC and it was stock for 3 or 4 months and I had no heat issues what so ever.
Old Jul 13, 2012 | 05:39 AM
jpooch00's Avatar
jpooch00
Good info & good news for me!
Thanks and ride safe
Old Jul 13, 2012 | 01:13 PM
stevieg's Avatar
stevieg
I've never ridden a tourer but my Heritage was REAL hot. You're sittin right on the oil tank on a Softail. I ended up buying an RJ heat shield which helped a little. 96ci (and I assume bigger) are hot engines, no doubt about it.
