So I got a used Chrome dash panel for my WG but did not know that they removed the toggle switch for the speedo on the 2012 model that my 2011 has. So now I will need to drill a hole and what wondering what is the best way to go instead of bringing it to a shop.
Yes you should punch it. I would measure from the old dash to get the location and use a piece of soft wood under where you are punching so the metal doesn't dent or cave in.
Thanks for the advice did not think about the piece of wood.
Another suggestion ... after using a punch or nail to locate the center ... use a smaller drill bit first ...
if the small hole is a little off your center, use a Dremel tool to 'center' the hole by removing material on the opposite side to which the hole is offset ... then drill out to the final hole diameter needed ...
