stator replacement?
Old Jul 29, 2012 | 11:04 PM
EastBay_Solo's Avatar
EastBay_Solo
Question stator replacement?
sup fellas is there any links on how to do this job step bye step.. I am purchasing a stator from a forum member to have it welded so i can do the install my self. Also any info on how to replace the bearing as well. any recommendation will be greatly appreciated.
Thank you
Old Jul 30, 2012 | 04:10 AM
cutter4292's Avatar
cutter4292
Check youtube.
Old Jul 30, 2012 | 03:34 PM
EastBay_Solo
ok will do thank you
Old Jul 31, 2012 | 05:06 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Search my recent Threads; I replaced a belt and upgraded my stator/rotor and IPB. A few pix and some recommendations in them. Pulling the IPB race was a MAJOR beeotch, even with the right tool...I'd prob'ly recommend the Dremel with a small diameter abrasive wheel, cut 80% thru, then split it with a chisel. Arbor press comes in handy for bearing remove/install. I replaced the stock with a 6205-Z (removed the seals)...it presses into the IPCase, and slip-fits on the input shaft. Double-check that bearing number, and buy quality.
Old Jul 31, 2012 | 05:43 PM
EastBay_Solo
thanks pkellymc i will look for you threads.
Greg Smith
Milwaukee Eight (M8)
Jan 16, 2018 11:21 AM
rlh7677
Feb 23, 2016 09:57 PM
FLTR2008TRIKE
53
Feb 12, 2012 03:03 PM
HELDVR
May 21, 2010 08:00 PM
HDF Tech
Dec 24, 2005 08:37 PM
