Switchback question
Old Nov 6, 2012 | 08:18 PM
FLD4sure's Avatar
FLD4sure
I read a post where it was said that it is way to expensive with the electronics and set up to do after the fact. Should buy it from the start.
Makes sense but don't now for sure.
The FLD probably will stop fine without it. Remember the old days with drum brakes in the back and NO brake in the front?
Old Nov 6, 2012 | 10:58 PM
ynots's Avatar
ynots
The FLD probably will stop fine without it?
if you want ABS I $uggest you buy it from the get go and not try and ad it later.
I know what its like to lock the front brake at freeway speed in a panic stop. Ive also low sided a bike from locking up the back tire while trying to avoid a car that pulled out in front of me.
Ive never had abs but cant help to think it could have saved me some damage
Old Nov 7, 2012 | 11:31 PM
FLD4sure's Avatar
FLD4sure
"The FLD probably will stop fine without it".
What I mean is that our FLD is criticized for having weak brakes and needing dual discs up front.
I had a fading front brake for a while, but after I had the front master cylinder replaced (recall) it stops great.
I have not ridden one without ABS, so "probably" stops fine - you tell me.
Still a great bike!
Old Nov 8, 2012 | 10:41 AM
tOSUSteve's Avatar
tOSUSteve
ABS can not be added at dealer.
jcanrun
Jul 5, 2016 02:42 PM
USMC_Vet
Apr 14, 2014 07:47 PM
elderberry99
Jan 17, 2013 09:21 PM
SUPRPIG
Jun 24, 2010 07:43 AM
dcassavar
Aug 30, 2009 11:58 PM
