Kickstand mod
Old Jan 20, 2013 | 09:43 AM
Gaterskiner's Avatar
Gaterskiner
6th Gear
Default Kickstand mod
I just got A 97 low rider after 20 years without A harley. I can't
put the freakin down Kickstand with my foot. I know I could come up with some kind of mod on my own but I thought I would ask here before I start designing A mod. Thanks.
Old Jan 20, 2013 | 09:46 AM
PigInaBlanket's Avatar
PigInaBlanket
They make little extensions you can bolt on the kickstand to help you get it down easier.
Old Jan 20, 2013 | 09:52 AM
Gaterskiner
6th Gear
Thanks I will look for one.
Old Jan 20, 2013 | 10:12 AM
Junkster's Avatar
Junkster
Took me awhile to get used to hooking my boot on it. Give it awhile you'll get used to it.
Old Jan 20, 2013 | 11:12 AM
Crazy's Avatar
Crazy
Use your heel, not your toe.
Old Jan 20, 2013 | 11:26 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
On my chopped bike, I used to put the stand down with my hand. I'm glad my FXS has the extension on the stand because it's so much easier.
Old Jan 20, 2013 | 11:50 AM
zukeeper's Avatar
zukeeper
extension is the best way I know of
Old Jan 20, 2013 | 11:58 AM
HYPR's Avatar
HYPR
Welding a simple extension is an easy solution if you weld. This is done by adding either a small plate or a U shaped curved section to the end of the stand. This will need to be bent upwards to clear both the ground and engine case.
Bob
Old Jan 20, 2013 | 12:01 PM
Mikey Ashie's Avatar
Mikey Ashie
Get the extension, its great... step your heel on it and pivot...
Old Jan 20, 2013 | 12:08 PM
Wakko47's Avatar
Wakko47
When it's raining I have a hard time with mine, heel or toe. I bought the big extension but it doesn't look like it'd fit quite right.
