Led tail light ?
Old Feb 19, 2013 | 07:21 PM
PistolPete83's Avatar
PistolPete83
Default Led tail light ?
I just installed the kuryakyn led tail light on my 12 fxdc and i was curious if anyone has had any issues with water getting inside the light???...the seal seams to be tight but i guess im just being proactive
Old Feb 19, 2013 | 08:21 PM
Jeffs386's Avatar
Jeffs386
if you are concerned you could always use a small amount of silicone
Old Feb 19, 2013 | 08:45 PM
PistolPete83
Good point. I think i may just to be sure
Old Feb 19, 2013 | 10:21 PM
brandon95354's Avatar
brandon95354
Default kuryakyn
kuryakyn instructions say to put the foam sealed piece with a sticky back in the light, then after that it says to use silicone to fully seal the light set up...
it defiantly says that in the instructions somewhere
Old Feb 20, 2013 | 12:37 AM
apehanger65's Avatar
apehanger65
i have had 3 of them on my 06 Street Bob... water was never the problem. the lead wire of the printed circuit board keeps breaking on them. I see now they redesigned them and have all new part numbers so hopefilly the fixed the problem. I wrote to them awhile back and they said they never had an issue with that problem(this was before i found this forum) this was after the 2nd one broke . I got 2yrs tops out of them . I plan on sending all 3 broken lights back with all the letters i wrote and recipts for the lights ....maybe they can do something for me . when the last one broke i was out of state on a holiday weekend and had to scramble to find an open dealer that had a stock taillight just so i could ride otherwise i would have had NO light, cost me an extra 70 bucks for something i had at home... oh well . Good luck with yours!!! just curious what are the part numbers on yours??
Old Feb 20, 2013 | 09:33 PM
PistolPete83
I put the gasket on so hopefully wont be an issue...if the problem exists where the circuit board is then i will make sure i would send it back because thats just defective my part number is i think 5438...
Old Feb 21, 2013 | 12:32 PM
apehanger65
ANY part #s starting with 5 are the newer impoved ones so hopefully they fixed the problem. the ones i had started with 4...i think 4828 was one of the #Si had 2 different models. good luck. if i ever write to them and send them ack i will let you know what they said
Old Feb 21, 2013 | 12:37 PM
apehanger65
as far as the seal ....i thought the same thing it seemed like it could be tighter but i never noticed any water in there...
Old Feb 22, 2013 | 11:19 AM
mp535th's Avatar
mp535th
I just bought one from custom dynamics. Used there products in the past and never had any issues...
Old Feb 22, 2013 | 11:30 AM
TexDyna06's Avatar
TexDyna06
3rd Gear
I had the same issue had but luckily was closer to home and slapped the original light back on. Got a newer version with different set up so hopefully it won't be an issue again.
Ape- Not sure who you ordered through but JP gave me credit when I sent broken one in.
Never a water issue though
