Broke a wire pin while changing handle bars....need help
I broke one of the pins at the end of a wire while pulling it through the bars. Not sure what the name of these are to even start looking for a replacement. It went into the plug with 6 wires on my 2011 SB
Any help??
Any help??
Probably a Molex connector pin. Should be able to get a new one from a HD shop and carefully use needle nose pliers to reattach - or you could buy a nice crimping tool, but $$$.
Ask the parts counter guy, they never show pin in parts microfiche.
HD sells them, they are crimp style super easy to install, i have several on hand for botht he older and new blade style, i break them on occasion as well internally wiring tough bars
If it's a pin in the HOUSING, 6-way pin (black) at the end of the handlebar switches' wiring you'll need a TERMINAL, pin, #16-20 AWG p/n 72169-07.
If it's a pin from the front turn signal wiring or the headlight wiring socket, you'll need a TERMINAL, socket, #16-20 AWG p/n 73191-96
