Electric plug help
Old Oct 25, 2014 | 10:59 AM
Granpita's Avatar
Granpita
Default Electric plug help
I am removing (for repairs) the fairing on my recently acquired 1984 FXRT. There hasn't been an issue until trying to separate the main plug and I just can't get it loose. I think it's #72038 and I'm having trouble determining where the release tabs are. Little cramped up in there. Are the release tabs on the broad sides or the narrower edges? And if everything is just corroded together in there, then what? Thanks.
Old Oct 25, 2014 | 01:48 PM
mkguitar's Avatar
mkguitar
jeez sorry can't remember about the tabs.
but shoot some wd40 in there if you think is is jammed up...
if you can get to one side, you could release each wire from the block
if you think it has welded itself together, signs of melting- cut
mike
Old Nov 6, 2014 | 05:47 PM
machinehed's Avatar
machinehed
Default connector blocks.
My manual for your model shows the locks on the narrow ends of the con. blocks but its best to have a good clear view of the connector to make sure where the locks are and to also pry them apart if they are stuck .
If i remember correctly the connector blocks are all white colored nylon type monoblocks , look for any dark discoloration on the connector.
If this discoloration is evident then the block is probably stuck together
due to overheating from loose connector pins/or pin recievers.
If con. block is toast you need to cut it out and replace it.
Do this ...
Make a diagram of the block and wire colors connected to it .
Count the number of wires connected to the con. block.
Go to any auto. parts store and purchase new male and female con. blocks and associated pins and pin recievers to accept the number of wires you counted .
Also ensure you have the proper crimping tools to do your repairs.
Old Nov 6, 2014 | 06:16 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Do this ...
In addition to the correct crimping tool I leave a little wire bare so that I can solder the wire to the male/female pin.
fullautomike
Sep 9, 2015 08:16 PM
JoeN
Audio Systems
Apr 20, 2014 06:00 PM
Alleyn
Dec 13, 2013 07:18 PM
WHOSNEXT
Sep 15, 2008 12:36 PM
yoseppi
Aug 20, 2008 09:48 PM
