Do it yourself paint
Old Feb 21, 2007 | 12:27 PM
davidchristopher's Avatar
davidchristopher
Default Do it yourself paint
Show of hands, and pics...
How many of you dyna guys (and gals?) have painted your own tins? How did it go? What did you use? What would you do different?
David
Old Feb 21, 2007 | 01:06 PM
2000fxdwg's Avatar
2000fxdwg
Default RE: Do it yourself paint
I restored a Yamaha back when I was in the military. Easiest color is black or white. I painted mine black lacquer since it is very forgiving. Base color is easy to spray...a lot of sanding...then the clearcoat, which is also easy to spray since you don't have to achieve a gloss spray...lots of sanding and then a buff and you'll get a deep glow.
Old Feb 23, 2007 | 01:50 PM
davidchristopher
Nobody else?
Old Feb 23, 2007 | 02:23 PM
dubblist's Avatar
dubblist
I'm sure your talking about more of a custom job or something more shiney but here's a couple I didnt with graphics, nothing fancy and not a HD but .......
Old Feb 23, 2007 | 02:25 PM
vicsponjr's Avatar
vicsponjr
Dublist, That is SWEET! Nice design!
Old Feb 23, 2007 | 04:39 PM
Night_Train01's Avatar
Night_Train01
I painted my own bike, this is the second bike I have painted. The secret is having the proper polishing equipment. I want to try gold leaf next and flake mixed in the clear.
[IMG]local://upfiles/6165/0B9CDDDFC0BE49D2AC21158EA5B1C39E.jpg[/IMG]
Old Feb 23, 2007 | 05:06 PM
piniongear's Avatar
piniongear
Yeah Dave.....
I painted my old Sportster here at home when I did the 5 year restoration. (Pictured as my signature photo here)
I used PPG catalyzed Urethane paint, and the related products that go with it such as epoxy primer, catalysts etc.
If you are going to paint your machine yourself (and I hope you do) this type of paint, and I do not mean this brand of paint, is the only way to go.
Surface prep is everything. Do that correctly and all else will go fine.
You remove the old paint, chemical clean the metal, etch with mild acid solution, prime and paint. Finish paint with 2 coats of clearcoat. The clear gives it the deep shine. No rubbing out is done, as you would have to do with lacquer.
This paint is bullet proof and fuel proof. Lacquer can be removed by simply spilling gasoline on it doing a fill up. Lacquer died out in 1959, so stay away from that stuff. Good luck.........pg
[IMG]local://upfiles/8331/4DBBD3D998E345869AAA50AB47B0A5F3.jpg[/IMG]
Old Feb 23, 2007 | 05:25 PM
dubblist's Avatar
dubblist
Man every time I see your bike I fall in love
Old Feb 23, 2007 | 07:27 PM
davidchristopher
Yeah- it looks awesome! I am indeed planning to do my own paint. I've not yet decided on a paint scheme though; I'm really looking forward to it. You're right. prepwork is KEY. Painting over crap give you painted crap. I have a second set of tins for my bike that I'm going to shoot the new paint on, so I can keep doing it until it's 100% what-I-want without any downtime on the bike.
It's gonna be an awesome spring, anyway
D
Old Feb 23, 2007 | 07:46 PM
Alaska Bobber's Avatar
Alaska Bobber
https://www.hdforums.com/m_1154086/tm.htm
Not nearly as hard as the body shop people try to make it out to be.
