200 Rear Conversion System
Old May 15, 2013 | 08:38 PM
Mithion's Avatar
Mithion
Default 200 Rear Conversion System
http://heartlandbiker.com/wide-tire-...ome-struts-1-1
This kit looks pretty good. IMHO anyhting wider than a 200 is ugly and cartoonish, but to each his own.
I wonder if you can use a seat other than the one that comes in the kit, the top shock mounts look very high hence the cutouts in the seat in the kit. I like that they offer the struts in black as well.
A bit expensive when you consider you also have to get a wheel and tire to go with it all but it def cleans up the rear end nicely.
Old May 15, 2013 | 08:47 PM
WG2011's Avatar
WG2011
All true but the price is tough to make it considerable.
Old May 15, 2013 | 08:51 PM
Mithion's Avatar
Mithion
http://www.chopper-kit-usa.com/fat_t...rley_DYNAl.htm
A bit cheaper down at the bottom of the page.
Old May 15, 2013 | 09:38 PM
SuperFastGlide's Avatar
SuperFastGlide
I have a 200 on mine... no system
Old May 15, 2013 | 11:19 PM
Jacoblb's Avatar
Jacoblb
I'm pretty sure I've seen some people throw a 200 on with minor mods
Old May 16, 2013 | 01:11 AM
dyna_jim's Avatar
dyna_jim
I also have a 200 with no mods..just rerouted my taillight harness down behind the strut legs..
Old May 16, 2013 | 06:09 AM
Mithion's Avatar
Mithion
That's awesome that you can fit a 200 no problem or mod, thank you for the info!!!
For a 2013 do you still have to relocate any tail light harness or anything wit it all being side mounted already?
Old May 16, 2013 | 08:22 AM
jmeiers's Avatar
jmeiers
For that price, you could get a 21x3.5 front wheel and tire and 18x5.5 rear wheel and tire, brand new, and do it yourself with your existing hardware.
200 tire fits under stock setup. My bike is slammed and the rear fender has been lowered and no issues or rubbing.
Do a search on 200 tire on a Dyna. It's been done many times and there are plenty of photos and stories about it.
Old May 16, 2013 | 08:26 AM
! rock103 !'s Avatar
! rock103 !
quote=jmeiers;11299494]For that price, you could get a 21x3.5 front wheel and tire and 18x5.5 rear wheel and tire, brand new, and do it yourself with your existing hardware.
Do a search on 200 tire on a Dyna. It's been done many times and there are plenty of photos and stories about it.[/quote]
Old May 16, 2013 | 05:02 PM
SuperFastGlide
you need a differant wheel... im using a crossbones 17"... others are running 18"s
