Looking to improve
Old Jun 22, 2013 | 05:35 PM
croyalc's Avatar
croyalc
Default Looking to improve
Hi all,
I bought my first Harley less than two weeks ago and am very much enjoying it. I am looking to put a sissy bar on it with a backrest for my wife. Since I am new to the Harley world (been riding off and on for about 15 years) I am not sure if I need to be looking at bars specifically for my bike or the Dyna Family, or will any bar work on a stock rear fender. I also have a skull L.E.D. fuel gauge that doesn't seem to work. I have found that there seems to be a lot of these gauges that do not work correctly. It seems that most people are just using their trip odometer to figure out how much fuel they have. I have been doing that and it seems to work fine. However, if anyone has figured out a fix for it, i would be interested in giving it a try.
Thanks for the feedback
Old Jun 22, 2013 | 05:38 PM
croyalc's Avatar
croyalc
Even though it is listed in my Garage, I have a 2004 Dyna Low Rider that appears to be stock with the exception of a few decorative pieces,some auxilliary lighting, and a set of Screaming Eagle II pipes.
Old Jun 22, 2013 | 06:26 PM
Chase1961's Avatar
Chase1961
First you'll need to get sideplates for your bike. Either rigid or detachable, if you go with detach, then you'll need the docking hardware also. Then choose a sissy bar. Looks like there are 4 sissy bars listed that will fit your bike.
Old Jun 22, 2013 | 06:33 PM
dirtdobber's Avatar
dirtdobber
If you are not planning on removing it I would consider the rigid mount.It goes behind the fender strut and has a much cleaner look to it.
You can get the rigid mount then the back rest or you can get a one piece that has both made or welded together.
This will give some to look at from HD. After market makes them to.
http://www.harley-davidson.com/shop/...avedmodelCode=
Just click on backrests and racks
Old Jun 22, 2013 | 06:42 PM
croyalc's Avatar
croyalc
If I end up putting quick release bags, can I use the ridgid mount sideplates? I would like to be able to put bags on when I need the storage but I plan on leaving the sissy bar on all the time. It looks like the mounting points are the same but I don't know if one is affected by the other. It looks like the side plates are only for mounting the sissy bar.
dynarider7
May 17, 2018 01:38 PM
B_Ross48
Jun 6, 2014 08:38 PM
littledragon
Apr 1, 2014 07:55 PM
BluBeaSSt
Aug 5, 2013 10:41 PM
peg20
May 9, 2013 07:19 AM
