2002 FXDX Accssory Connector Location
I'm putting an auxiliary running light on my 2002 FXDX and would rather not splice into any wires. I've done some research, and seems the best way would be to use the Accessory Connector. Problem is, I can't locate it on this bike. On my StreetBob, it's under the seat. Easy. All I've found othe DX is the Data port under the fuse cover.
Any tips?
Any tips?
Any tips?
Any tips?
Here's how I wired my aux lights (switch feed connected to low beam wire in headlight bucket):
To connect the 12v relay feed wire just solder/crimp a ring terminal connector to the wire that runs to pin 30 at the relay and attach the ring to the copper stud at the circuit breaker behind the fuse panel or to the plus pole at the battery.
