rear brake problems
Old Sep 10, 2013 | 04:39 PM
rsking45's Avatar
rsking45
Default rear brake problems
I go to leave work today I get to the first stop sign hit the brakes and stop.I go to go again and I can feel the bike not wanting to move thats when I noticed that the foot brake didnt return back to its normal position and the brakes were dragging.I had to pull the foot brake back to release the rear brakes.I got home,tried the rear brakes again and same thing.
Any ideas,bad mastercylinder, caliper ?
Old Sep 10, 2013 | 06:12 PM
mattVA's Avatar
mattVA
Let me guess: does the bike have forward controls?
Old Sep 10, 2013 | 06:15 PM
skinman13's Avatar
skinman13
Year and model?
Old Sep 10, 2013 | 06:22 PM
mattVA's Avatar
mattVA
I saw you have a 2011 WG in another thread. So the fix is easy. You'll need a drill or rotary tool with a sanding bit. You will need to remove your right foot peg. Behind this footpeg is a torx head bolt. Remove this. But be careful not to strip it out with the wrong size socket. Once that's out, your brake pedal should be free except for the part that connects it to your rear brake rod. You'll have to get the clevis pin out. Now that all that is done you can confirm what I suspect: the brake pedal is not rotating smoothly even though nothing is connected to it. There's a plastic bushing that it rides on. I had to use a dremel and sanding bit to ream out the plastic bushing. Once that was done I bought some high temp grease and lubed it up. Re-assembled with loctite where appropriate and has not been an issue since.
Matt
edit: more details here. Follow the pictures and you'll be set: https://www.hdforums.com/forum/dyna-...ticking-2.html
Old Sep 10, 2013 | 06:35 PM
KEYBEAR's Avatar
KEYBEAR
I agree with MattVA . Every WideGlide (4) I have had to do the same thing .
Take you time make it smooth and grease the hell out of it .
Old Sep 10, 2013 | 08:50 PM
rsking45's Avatar
rsking45
Yes it is a 2011 Wide Glide With forward controls. When I got home from work I didn't have time to mess around with it. Well I'm home now and I cannot get it to Stick like it was. Thanks for the info guys I'll definitely give that a try
Old Sep 11, 2013 | 08:00 AM
mattVA's Avatar
mattVA
Mine always came and went with heat from outside and heat from the engine. Best to take care of it. When I was done sanding and greasing the plastic bushing, the metal keyed piece removed to access the plastic bushing slid right in, whereas I had to knock it out with a mallet before I messed with it. It should rotate smoothly by hand.
Old Sep 11, 2013 | 10:35 AM
rsking45's Avatar
rsking45
I'm going to take it apart tonight after work and take care of it so it doesn't happen again. I appreciate everybody's info.
T Man
Dec 13, 2017 09:18 PM
spike95
Sep 7, 2014 08:06 PM
WideGlideFever
Feb 9, 2013 06:10 PM
ncbeast
May 30, 2011 09:16 PM
phalcone
May 9, 2006 09:10 PM
